Leaking top - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Leaking top
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Unread 02-22-2003, 12:34 PM   #1
JSBlu974X4
Leaking top
Hey my stock soft-top is leaking here and there and is there any glue or jeep stuff that you can use the stop the leak until i buy a new top?
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline   Reply With Quote
Unread 02-22-2003, 08:12 PM   #2
macb
go by your local wallymart in the camping goods section and pick
up tent sealer...works great on my camping gear and it also worked
on my top until it was replaced under warranty...just apply it on
the inside of the threads or wherever it is leaking. It will waterproof
and also stay flexible.
HTH
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah: [URL]http://www.sajeeps.com[/URL]
[url=http://www.cafepress.com/H2RT]No Bling - H2 Recovery Gear[/url]
Bob Supplee:supplee@ionet.net or (405) 799-8977
Stu Olson's great jeep resource site: [url=http://www.stu-offroad.com]www.stu-offroad.com[/url]
macb is offline   Reply With Quote
Unread 02-22-2003, 09:01 PM   #3
JSBlu974X4
thanks alot
Unread 02-23-2003, 02:12 AM   #4
JeepinOgre
Duck tape will fix everything that could ever go wrong with your jeep. Trust in the power of the tape.
2000 Silver TJ, 33x12.5 procomp x-terrains, lot's of lights and other stuff.
Ogre like Donuts.
H2 RECOVERY TEAM Pleasanton Chapter
[COLOR=RED]If it moves kill it. If it dosent move eat it.[/COLOR]
JeepinOgre is offline   Reply With Quote
