Leaking thermostat - JeepForum.com
post #1 of 14 Old 07-13-2010, 04:52 PM Thread Starter
firemedicjth
Leaking thermostat
I replaced my water pump and thermostat on my '01. I replaced the gasket (after cleaning the old one off) and I keep getting a leak from the thermostat housing somewhere. I thought it wasn't tight enough and with a slight push I managed to crack and break the old housing. 45 minutes and $60 later I had a new housing and it's leaking also. Any suggestions?
firemedicjth is offline
post #2 of 14 Old 07-13-2010, 04:56 PM
cajunfireman
I had the same problems. I always buy a couple extra gaskets any time that I replace a thermostat. I ended up using some silicone gasket and it hasn't leaked since.
2000 Jeep Wrangler Sahara
Firefighter Jeep Club Member #337
"Greater love hath no man than this, that a man lay down his life for his friends." -John 15:13
Fight Crime....Shoot Back
I'll keep my money, my guns, and my freedom. You can stick the change up your ***.
cajunfireman is offline
post #3 of 14 Old 07-13-2010, 05:11 PM
lamigra
Junior Member
lamigra's Avatar
I just did the exact same thing! The housing breaks really easy. I ended up with a dremel and wire wheel to get ALL the old gasket off and it hasn't leaked.
lamigra is offline
post #4 of 14 Old 07-13-2010, 05:18 PM
BlueFlame
BlueFlame's Avatar
2 common problems:
1. Not getting the tstat in straight, so the housing won't tighten down properly.
2. Not putting the housing on straight and not carefully snugging down the bolts evenly, so it gets tweaked and..you guessed it..cracked.
BlueFlame is offline
post #5 of 14 Old 07-13-2010, 06:04 PM
biffgnar
biffgnar's Avatar
x2! My mistake when a changed thermostat a few months ago.
biffgnar is offline
post #6 of 14 Old 04-14-2011, 01:34 AM
martinCT
having truble to find Wrangler thermostat in SA ( only one shop seling Mopar's thermostat for 70$????)
this is bit too much....
tryed to fit thermostat from sam other cars...what is a diameter of Wrangler thermostat? temp is 195, that i know....
Anybody know for replacement model ?
martinCT is offline
post #7 of 14 Old 04-14-2011, 08:46 AM
WakeUpTheSun
The quadratech thermostat housing is $10 lol
http://www.quadratec.com/products/51209_08.htm
My totally unique and never before seen signature.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
WakeUpTheSun is offline
post #8 of 14 Old 04-14-2011, 10:28 AM
vosevichs
South Africa? Local parts stores don't carry the stat?
I put a couple of dabs of silicone on head then installed the stat. The silicone will hold it in place.
Scott Vosevich
vosevichs is offline
post #9 of 14 Old 04-14-2011, 01:00 PM
martinCT
SA is not really Jeep country - loots if Toyota’s around...keep about 60% of market....and Land Rovers...
Only one jeep dealer have Mopar parts on killer price of 70-$ USA
Having a Jeep here become as luxury...nonsense
I browse other shops and finally found one today with same temp range, size 48mm DIA, and perfectly fits in housing-cost 8$usa and is made for Golf???
Problem solved, thanks for advices...I just like American cars
martinCT is offline
post #10 of 14 Old 04-14-2011, 01:20 PM
oakmckinley
Thermostat goes in first, I know one time I had actually put the gasket on then the thermostat, and it looked funky then I realized my mistake.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #11 of 14 Old 04-14-2011, 01:46 PM
SilverTJMike
Wet the gasket per the Factory Service Manual, use a torque wrench and never had an issue.
SilverTJMike is offline
post #12 of 14 Old 07-31-2012, 07:04 PM
BF511
A dab of sealant to hold the thermostat while carefully positioning the housing is KEY !
BF511 is offline
post #13 of 14 Old 11-10-2012, 09:45 PM
JeepJohn92
1988 XJ Cherokee
I busted my housing too, once. Sealant on the housing then place the gasket, doesnt take too much torque which took me 3 sealants to learn. Just get it on finger tight, both, then torque it down snug then about a quater turn. Let it dry for about it hour and you should be alright. I know its not a Wrangler but hey, its the same basic procedure.
Colorado Jeep Club Member #343
Built not bought.
JeepJohn92 is offline
post #14 of 14 Old 11-10-2012, 11:03 PM
chris142
The thermostat is a very common size. It also fits Chevy V8's (283,327,350, 396,454) up to around 1994 or so. It also fits Ford V8's(289,302,351M,351C,351w,400 and 460s from 1960ish to the last year of the 460 which was the mid to late 90's.
chris142 is offline
Leaking , coolant , thermostat , water pump , gasket
Thermostat housing leaking jeepster1976 YJ Wrangler Technical Forum 12 06-10-2010 09:45 AM
leaking new thermostat CO_crawler TJ Wrangler Technical Forum 7 04-29-2009 07:55 AM
Thermostat housing wont stop leaking manofmany TJ Wrangler Technical Forum 8 11-08-2007 11:58 AM
Thermostat FNG TJ Wrangler Technical Forum 1 06-30-2005 01:33 AM
4.L Thermostat ian-X TJ Wrangler Technical Forum 9 07-28-2003 11:50 PM
