Leaking from rear end. What is broken? I have a picture - Page 2 - JeepForum.com
post #16 of 21 Old 08-13-2010, 05:44 AM
j_niko
2009 JK Wrangler
Remove the plug again to make sure there is still some fluid in there. Chances are it's fine. One drop of thick oil can make an impressive puddle.
j_niko is offline
post #17 of 21 Old 08-13-2010, 05:45 AM
GETTEMTJ
It will be fine for a 10 mile hike..
GETTEMTJ is offline
post #18 of 21 Old 08-13-2010, 05:59 AM
tractor1
1979 CJ5
If you went in the deep water when wheeling i would change the oil. water may have gotting in.
tractor1 is offline
post #19 of 21 Old 08-13-2010, 06:59 AM
snakester14
X2 on that
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline
post #20 of 21 Old 08-13-2010, 09:44 AM
dcope17
Well, if it's that overfilled, perhaps its filled with oil and water????
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #21 of 21 Old 08-13-2010, 09:56 AM
PeteYJTJ
I guess if it were me I'd at least try to pull some of the weeds out, one by one, to help the seal close up and, umm... seal.
Not sure if it would help or make matters worse, but I'd probably still try it.
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
crush sleeve , d 35 , dana 35 , pinion nut , pinion seal
proportioning valve leaking, broken bleeder? offrdjeepfreak8 YJ Wrangler Technical Forum 2 04-05-2010 08:07 PM
broken turn signal lever & leaking transmission laredo89 YJ Wrangler Technical Forum 2 03-02-2008 07:47 PM
What's broken in this picture? U-Joint Issues? DJMunich TJ Wrangler Technical Forum 31 03-09-2007 02:52 PM
Leaking PS Box, Broken End Links and Worn Out Shocks Rick Anderson TJ Wrangler Technical Forum 2 05-10-2004 05:22 PM
Picture of my broken locker Jeep-Ne-Time TJ Wrangler Technical Forum 3 02-29-2004 02:14 PM
