Leaking Heater Core - JeepForum.com
post #1 of 18 Old 09-06-2008, 10:24 AM Thread Starter
CO_crawler
Leaking Heater Core
So, I have had clear water leaking out of my drip line for the heater core for about 9 months. I have always had heat and A/C, and the only problem that I can see is that I am losing coolant fluid levels. When is it time to replace the heater core? Are there problems with doing this with a TJ that has A/C like mine does? Thanks!
I just read that you have to take out the whole dash and drop the steering column....
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
post #2 of 18 Old 09-06-2008, 10:58 AM
LJameson
Are you sure it's the heater core? Earlier TJ's have a common problem of leaking the condensation from the A/C into the passenger floorboard. Also, you say the drip line? Are you sure that isn't just the condensation from A/C? If so, thats completely normal. In fact, you want that. Just keep on mind that the A/C runs when it's on the defrost settings too.
1990 YJ
LJameson is online now
post #3 of 18 Old 09-06-2008, 11:18 AM
BringThaPain
My 97 leaks condensation of the passenger side at times too. A bad heater core will be noticeable, as in you will smell antifreeze coming out of your vents.
BringThaPain is offline
post #4 of 18 Old 09-06-2008, 11:29 AM
Sarge37
If it is the heater core leaking, you can try some good stop leak from any auto store. Make sure to follow instructions and run the heater when you put it in the radiator.
"If It Aint Broke, Fix It Till It Is!!!!!"
05 TJ Rubicon, 4.0L, 6 Speed.
07 Ram 1500 Quad Cab
Sarge37 is offline
post #5 of 18 Old 09-06-2008, 12:30 PM
UTWeezul
If it is the heater core, I feel sorry for you. Mine went out and was a pain to get to and replace. You will also need the A/C system evacuated before doing the removal/install.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #6 of 18 Old 09-06-2008, 12:37 PM
durango-bob
2006 WK
Since you said that the fluid that was coming out of the hose was clear, I would say that it was just condensed water from the AC system. So your heater core sounds OK to me. As for coolant being lost, do you ever see the overflow bottle dripping any out? Is your exhaust smoke white? Is your radiator cap good and is it tight? Is there any sign of coolant leaking from the radiator where the plastic tanks are connected to the heat exchanger? Is the overflow hose properly attached at both ends? Do you ever see puddles of coolant under the Jeep after it has been driven and parked?
durango-bob is offline
post #7 of 18 Old 09-06-2008, 12:38 PM Thread Starter
CO_crawler
Uh NO stop leak is the worst thing ever to put into you cooling system. Appears that the heater core is fine but my radiator fluid is brown. Looks like the used car dealer or previous owner used stop leak on this and it is disgusting, will need all new hoses, radiator, etc....the works. I am not taking this one out on the trail next week in crested butte either....that sucks.
CO_Crawler
post #8 of 18 Old 09-06-2008, 01:20 PM
LJameson
I hear ya with that. I hate stop leak. When my grandpa had our CJ7, he took it to the shop to get a Freeze Plug fixed. Instead of fixing it, they put in leak stop. He wasen't happy with this, but couldn't do anything about it. Then when we pulled the engine out, we realized that the stop leak clogged the coolant passages from the block to the head! Not only that, but it looked like gravy...
1990 YJ
post #9 of 18 Old 09-06-2008, 01:45 PM
Sarge37
Yes I agree about the stop leak, it is a quick fix until you have the time or cash to do a permanant repair. I have replaced an AC Condensor on a 89 Daytona and had to remove the complete dash and console. It was an all day job. I agree that if it is clear water its not the heater core. You will smell it through the heater/AC vents if the core was leaking.
Sarge37 is offline
post #10 of 18 Old 09-07-2008, 09:11 PM Thread Starter
CO_crawler
yeah that pic is exactly what I am talking about. I tried to clean the overflow resevoir and it is like gum, cant get any of it out. That stuff is worthless. Is there anything that will disolve it the next time I flush my cooling system?
CO_Crawler
post #11 of 18 Old 09-07-2008, 09:29 PM
jprs_peeprs
Just Say NO! to stop leak...
C.
jprs_peeprs is offline
post #12 of 18 Old 09-21-2008, 12:26 PM
myriad360
2008 WJ
C.
x2. Unless you like gumming up your cooling system and replacing all the heater core / radiator parts later because they are so gummed up, they don't cool anymore. This is why I am doing my heater core... somone put that stuff in there, and it no longer recirculates any coolant into the heater core.
You would be way better off just bypassing whatever unit you are trying to stop leak, since that is pretty much what you are doing with it. Worthless gunk.
Great XJ Troubleshooting/mod sites list:
2001 Jeep Cherokee 4.0 L Limited, White. Bought in Grangeville, ID 06/11/08. Stock everything.
1998 Jeep Wrangle 4.0 L, Green. Bought in Nampa, ID 02/21/09
1988 Jeep Cherokee 4.0 L, White. Bought in Vancouver, WA in 2003. 1st Jeep, White. Bought with 3" lift, added Pacesetter header and 40 series Flowmaster
myriad360 is offline
post #13 of 18 Old 09-21-2008, 06:05 PM
MoJeeper
2009 JK Wrangler
It maybe a farmer thing, but we use pepper in our coolant systems if were in a pinch and have a leak..Its work very well.
09 JKU Sahara
MoJeeper is offline
post #14 of 18 Old 09-21-2008, 09:12 PM
LJameson
I've heard of something like that, but with cracking an egg in your radiator.
1990 YJ
post #15 of 18 Old 09-21-2008, 10:16 PM
Tom Hartz
1967 CJ5
Pepper does work, I have done it.
Tom
Tom Hartz is offline
heater core leaking ? RichRichards TJ Wrangler Technical Forum 3 02-09-2010 10:22 PM
Possible Heater Core Leaking HanksRide YJ Wrangler Technical Forum 7 02-17-2009 06:49 PM
Heater core leaking AFTER new one installed! Lovemyyj YJ Wrangler Technical Forum 4 06-02-2008 01:04 PM
heater core leaking Tuff350ss TJ Wrangler Technical Forum 1 11-12-2007 10:27 AM
Heater core leaking on my TJ! DCGayhart TJ Wrangler Technical Forum 3 10-16-2006 08:34 PM
