Leaking coolant? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Leaking coolant?
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 09-22-2007, 01:50 PM   #1
cb19950
Leaking coolant?
Im leaking tons of coolant...it leaks from right behind the belts down the front of the oil pan...im assuming its the water pump...should i get a stock water pump or upgrade it?
thanks
2000 TJ
When we do right, no one remembers. When we do wrong, no one forgets.
cb19950 is offline   Reply With Quote
Unread 09-22-2007, 02:09 PM   #2
BlkBird
As always, Id say upgrade while you have have to do it anyway. I just FlowKooler though and they dont have a listing for 2000 4.0, only 2.5's Im not sure of any other company that does a pump for the 4.0's.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline   Reply With Quote
Unread 09-22-2007, 02:18 PM   #3
cb19950
i think ima buy this...it look ok?
http://store.summitracing.com/partde...84+4294924666+
2000 TJ
Unread 09-22-2007, 02:21 PM   #4
JFM626
how long did the factory one last you? The oem is fine. Upgrading is unnecessary, get a factory replacement, not a jobber type.
JFM626 is offline   Reply With Quote
Unread 09-22-2007, 02:24 PM   #5
Big-E
What will a high performance pump do for a Jeep?
Big-E
Louisiana
2000 Sport
Big-E is offline   Reply With Quote
Unread 09-22-2007, 02:28 PM   #6
BlkBird
Originally Posted by cb19950
That looks like a nice piece and nice price. Just curious though, in the "check to make sure this fits your application" it lists the 4.0 and the 2.5 Do they use the same water pumps in the 4.0 AND 2.5?
2004 Wrangler X 4.0
Unread 09-22-2007, 02:29 PM   #7
cb19950
im at just over 66,000....ya thats a good point...
2000 TJ
Unread 09-22-2007, 02:30 PM   #8
cb19950
click Application and it says 4.0 1997-2002
2000 TJ
Unread 09-22-2007, 02:30 PM   #9
BlkBird
Hopefully keep the temp. down like it would for any other vehicle. Are Jeeps immune to high performance parts?
2004 Wrangler X 4.0
Unread 09-22-2007, 02:31 PM   #10
cb19950
so this is what yall think i should get?
http://store.summitracing.com/partde...6+&appfilter=1
2000 TJ
Unread 09-22-2007, 02:35 PM   #11
BlkBird
Thats what I would go with but I know everyone else on here thinks its impossible to improve anything on the 4.0.
2004 Wrangler X 4.0
Unread 09-22-2007, 02:47 PM   #12
Stu Olson
Stu Olson's Avatar
Keep the cooling system at 210 degrees F if everything is working OK....much like the factory water pump.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Unread 09-22-2007, 02:53 PM   #13
cb19950
so go with the high perforamce...it gets pretty hot do here in texas to
2000 TJ
Unread 09-23-2007, 05:08 AM   #14
cb19950
so do i go with the high performance one?
2000 TJ
Unread 09-23-2007, 09:08 AM   #15
Stu Olson
Stu Olson's Avatar
The last high performance water pump I helped a fellow Jeeper install left me less than impressed.
Here is a photo of the stock pump we removed....
Here is a photo of the high performance pump we installed (and it was one of the name brand pumps you see in the magazine ads).....
The company cuts a piece of sheet metal and pop rivets it onto a stock pump.....charges you a bunch more money.....and tells you that you may need multiple water pump gaskets to properly space out the pump so the rivet heads don't grind off on the engine block.
wow.....wasn't that a great investment!
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
