Leaking Coolant... - JeepForum.com
post #1 of 19 Old 03-30-2011, 03:36 PM Thread Starter
B2CARPEN
Leaking Coolant...
Hello, Looking for some help with anyone else that might have heard of or experienced this issue.
My 4.0 is leaking coolant from the front of the engine which appears to be coming out directly at the front lip of the crankshaft case right below the lower pulley. It does not leak at all when the engine is cool, only when it reaches normal temps. I know that there isn't (I should say shouldn't be) coolant in the crankshaft case, so my initial thought was that it might have been pouring down from the water pump, thermostat housing, or one of the front hoses. So I replaced the water pump since it was over 4 years old anyway, replaced the thermostat, completely scarped off and cleaned the gasket surfaces, and used RTV to help seal things up. I also checked the hoses and although they look old, seemed to hold up well and did not have any cracks or tears.
After all was said and done, I tested it out and I still experienced the same issues. Held up fine until the engine got up to normal operating temps then the leaking began again. All the signs point to a leaking water pump but I made certain to completely remove all remnants and sand the surfaces smooth prior to installing the new unit. Same went with the Thermostat.
I rented a pressurizer to test the system since it's too difficult to see exactly where it's coming from with the fan blowing. I will be tackling this again on Friday, but until then does anyone have any ideas, anything else I should check, thanks!
Founder of
B2CARPEN is offline
post #2 of 19 Old 03-30-2011, 04:56 PM Thread Starter
B2CARPEN
Bump...
Founder of
B2CARPEN is offline
post #3 of 19 Old 03-30-2011, 05:10 PM
wushaw
Rockin jeep
wushaw's Avatar
Nope, it sounds like the pressure check should help you locate it pretty quick. You shouldn't have to run the engine to pressure check it so get ya a mirror and a flashlight to pinpoint it.
wushaw is offline
post #4 of 19 Old 03-30-2011, 05:14 PM
baldeagle1
It was suggested to me couple weeks ago to rent tool from a Parts store. Most give your money back when returning tool. So, it really is a tool loan.
baldeagle1 is offline
post #5 of 19 Old 03-30-2011, 05:16 PM Thread Starter
B2CARPEN
Thanks Wushaw, any possibility it would be getting into the crankshaft and leaking out?
By the way, not too often you see that older model silver, nice jeep!
Founder of
B2CARPEN is offline
post #6 of 19 Old 03-30-2011, 05:19 PM Thread Starter
B2CARPEN
Yep, that's what I did and plan to test it out using the coolant system pressurizer tomorrow. It was free as long as I return the tool of course.
Founder of
B2CARPEN is offline
post #7 of 19 Old 03-30-2011, 05:58 PM
steelmillman
Your head gasket is a possible culprit.
steelmillman is offline
post #8 of 19 Old 03-30-2011, 06:09 PM
wushaw
Rockin jeep
wushaw's Avatar
It's desert tan Coolant leaking from the crankshaft ft. seal would be almost impossible and if it was your oil would look like a chocolate milk shake.
wushaw is offline
post #9 of 19 Old 03-30-2011, 06:13 PM
djfuzzy
Check your thermostat housing (water outlet) to make sure there isn't a crack in it from putting it back on your Jeep. They crack extremely easy, I learned the hard way.
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #10 of 19 Old 03-30-2011, 06:19 PM Thread Starter
B2CARPEN
Thanks guys for all the help and replies! I really appreciate it!
djfuzzy - I think you might be on to something... I do remember a sharp "crack" sound when tightening the thermostat housing back on. I loosened it, took it off and gave it a quick look over but it was too difficult to see any cracks or damage since there was RTV sealant all over the surface of it. When I went to tighten it back into place it did not make a crack noise again. I'll start there, remove it and clean it up to see if there's any damage.
Again, thank you all for the help. I hope to have this solved once and for all.
Founder of
B2CARPEN is offline
post #11 of 19 Old 03-30-2011, 06:33 PM
djfuzzy
That's exactly what happened when I broke mine. Just a few turns of the wrench and snap! Sounds like a big twisted straw popping.
USMC 2006-Present
djfuzzy is offline
post #12 of 19 Old 03-30-2011, 06:34 PM Thread Starter
B2CARPEN
Yep, exactly! Now I might as well upgrade to a high flow housing if that's the case. Hopefully not too expensive. What did yours run you?
Founder of
B2CARPEN is offline
post #13 of 19 Old 03-30-2011, 06:39 PM
SilverTJMike
Hesco has the high flow for like 20 bucks.
SilverTJMike is offline
post #14 of 19 Old 03-30-2011, 07:13 PM
djfuzzy
Not sure of the brand, but I got the "expensive" one from NAPA. I think it ran me about $35 (aloha price ). I didn't notice any differences in the size of the ports on it, so I don't believe it to be high flow. But it definitely doesn't leak as much coolant as the cracked one did.
USMC 2006-Present
djfuzzy is offline
post #15 of 19 Old 03-31-2011, 10:21 AM Thread Starter
B2CARPEN
Thanks guys, I really appreciate the info. I might just be getting whatever brand I can find in stock tomorrow since I need to get the heep back on the road again soon. I will post updates as soon as I can. Thanks again!
Founder of
B2CARPEN is offline
Leaking coolant! xtrmjeep YJ Wrangler Technical Forum 15 03-19-2010 08:59 PM
Leaking Coolant need help Wishmaster22 TJ Wrangler Technical Forum 14 09-23-2009 11:01 AM
another leaking coolant ? langston.4 TJ Wrangler Technical Forum 5 01-16-2007 11:55 PM
Coolant Leaking? pharmacist25 TJ Wrangler Technical Forum 7 10-24-2006 03:44 PM
Leaking coolant Nymisus YJ Wrangler Technical Forum 7 08-15-2003 03:25 PM
