Leaking Brake Line - How hard to repair? - JeepForum.com
post #1 of 8 Old 08-06-2011, 02:35 PM Thread Starter
mmitsch
The brake line in my daughter's 1999 Wrangler Sahara sprung a leak this afternoon. She said she was driving and noticed less response from the brakes and that the brake light was on (on the dash) and wouldn't go off.
After putting some brake fluid in (it was very low) and having my son watch the brake light I noticed fluid leaking from under the Jeep just behind the drivers side doon. I got down there and, sure enough, a pretty fast leak is coming from a pretty rusted brake line.
So, how hard is this to replace? Is this a job I can do myself? Can I just get the brake line at the auto parts store?
Let me know.
mmitsch is offline
post #2 of 8 Old 08-06-2011, 02:50 PM
Brian2o0o
You need to figure out where the leak is coming from exactly then go from there. Is it the metal lines or the flexable line that runs to the caliper? The flexible line would be the easier of the two to replace. Just make sure to bleed the brakes after you replace what's leaking to remove the air from the lines.
2013 JKU sport, 3.25 RC lift, 35" BFG KM2s, JCR bumpers, Smittybilt winch
Brian2o0o is offline
post #3 of 8 Old 08-06-2011, 04:37 PM Thread Starter
mmitsch
It was a metal line. I took the line off and went to the auto parts store and got new line (had to get 3 pieces, some unions and a tubing bender). I was pretty nervous about this project but just came in from the driveway -- the new line is in and routed through all of its original clips!
Unfortunately the brake light is still on and the brake pedal is mushy but there are no leaks. I filled the resrevoir with brake fluid too. I think I need to bleed these but I have absolutely no idea how to do that. I am wondering if I should take it to Sears for that part?
Let me know what you think and thanks for the response!
mmitsch is offline
post #4 of 8 Old 08-06-2011, 05:23 PM
Cesaros
http://stu-offroad.com/suspension/bleed/brakebleed.htm is where you need to look for brake bleed instructions.
It's very easy if you have 2 people. If you don't feel comfortable DIY, it can be relatively inexpensive to just have them bled...be cautious of places trying to tell you that you did somthing wrong and you then need to spend $XXX to replace it.
I wouldn't even drive it until you bleed the brakes...that much air in the lines is a recipe for disaster.
Cesaros is offline
post #5 of 8 Old 08-06-2011, 06:57 PM
chris142
If you open the RR bleeder and let it drip then close that bleeder and open the LR one and let that one drip it should self bleed. If that doesn't do it have daughter hold the brake pedal while you open and close the RR then LR bleeders.
chris142 is offline
post #6 of 8 Old 08-06-2011, 08:28 PM Thread Starter
mmitsch
I got everything working! This morning when I got up I never would have believed I would have bent brake line and bled brakes -- but now I've done both! There was a bunch of air in the new line. I had to have my son pump on brake pedal but, after a few bumps with air coming out, I got a nice stream of fluid. Did the other rear wheel and the 2 front as well (bled them a little) and the brake pedal feels great and the brake light on the dash is off.
Thanks for your help (all the others too). Hey, do you think I ought to replace all the brake lines?
mmitsch is offline
post #7 of 8 Old 08-06-2011, 08:30 PM Thread Starter
mmitsch
Did as you said and all is working! I feel great about learning something today! There was a bunch of air in the new line and, once I bled each wheel a little bit, the mushy feel went away and the brake light went off!
Thanks for the help!
mmitsch is offline
post #8 of 8 Old 08-07-2011, 10:28 AM
Brian2o0o
Glad you got it figured out, I didn't catch that it was the rear line leaking. I would go ahead and replace the other lines if they are in the same condition. The right tools and a little bit of guidance can go a long way. I'd never done anything other than change the oil before I got a jeep, but now I'm pretty comfortable tackling just about anything but an engine or tranny rebuild.
Brake Line Fender Repair Pic Needed PhatJK JK Wrangler Technical Forum 7 07-15-2011 09:23 PM
leaking brake line driftbandito YJ Wrangler Technical Forum 12 10-27-2009 08:29 AM
Leaking brake line Mike Davis YJ Wrangler Technical Forum 6 10-25-2007 03:34 PM
Brake line leaking HipCheck_1 TJ Wrangler Technical Forum 2 09-23-2007 10:36 PM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 07:24 PM
