Leak on drivers side of 2001 Jeep Wrangler - JeepForum.com
post #1 of 1 Old 05-31-2010, 09:18 AM Thread Starter
obiwon
I think I've found my leak. It's the soft top front seal on the drivers side. I found a water mark on the inside of the Jeep at the corner where the top and front door meet. From the water mark, it would drip directly down into the floorboard which explains why it is dry under the brake and gas pedal area but can get totally soaked from the front door joint back towards the front seat.
I found a gap which might be normal on the rubber seal that is attached to the top frame above the windshield on the drivers and passenger side. Under normal circumstances I would assume this would divert excess water out and away from dripping inside the jeep but for some reason, either my top has an issue in closing tightly in that area or the ridge that runs along the seal stops at both corners and water is not diverted away and outside but dripping inside. I was wondering if I could put some silicone caulk at that point on each side to try and keep the water from dripping inside the vehicle or if that's a bad idea.
I'm going to check with the local jeep place and see if my front seal needs to be replaced or if the problem is my top where it comes down on top of the seal but was hoping to make a temporary fix with the silicone caulk if that will work or should even be done. Any ideas or suggestions greatly appreciated.
obiwon is offline
leak , seal
99 TJ Help!- Water Leak Drivers Side Floor MIG3 TJ Wrangler Technical Forum 4 11-15-2010 12:21 AM
2001 TJ Passenger Side Water Leak jaxwrangler TJ Wrangler Technical Forum 0 06-19-2008 06:04 AM
Jeep pulling to drivers side. jedeason TJ Wrangler Technical Forum 6 05-06-2006 03:56 PM
jeep pulling to the drivers side cmadden57 TJ Wrangler Technical Forum 12 04-24-2006 12:50 PM
Jeep Floorboard/Drivers Side Replacement Pannel? bcshepard YJ Wrangler Technical Forum 2 02-18-2005 07:44 AM
