Leak Detection Pump - JeepForum.com
post #1 of 8 Old 06-08-2009, 12:51 AM Thread Starter
mlelah
Leak Detection Pump
My CEL is on (P0442 and P0455). It's been on most of the time, but sometimes goes off when I refuel. I've checked all the hoses, and replaced the fuel cap (but not pulled the gas tank). I understand that the Leak Detection pump may be wearing out. Is there a way I can check this? There is no code for the LDP so its electricals must be fine. Thanks.
mlelah is offline
post #2 of 8 Old 06-08-2009, 01:07 AM
-sean-
-sean-'s Avatar
1944 CJ2
If it was the LDP you would be getting the code for it. I forget the number.
What are those codes for?
You can unplug the LDP and see what codes you get.
-sean- is offline
post #3 of 8 Old 06-08-2009, 01:23 AM Thread Starter
mlelah
The codes are for small and large emissions leak. But if I unplug the LDP, now the computer can't measure the system?
mlelah is offline
post #4 of 8 Old 06-08-2009, 06:08 PM
WahooCreek
Double check the black rubber hoses which connect the hard lines. If one looks cracked, it is likely your problem. Doesn't have to be cracked much.
I had same codes on my 03. Turned out to be the black rubber hose at the base of the firewall which connects the hard line coming from the fender to the hardline which runs along the frame.
What I did to diagnose was simply wrap the suspected black rubber hose with electrical tape to seal it up. Reset the computer/disconnected and reconnected battery. By the way, that tape lasted for 9 months.
Good luck.
WahooCreek is offline
post #5 of 8 Old 06-09-2009, 12:10 AM
-sean-
-sean-'s Avatar
1944 CJ2
Odd, my LDP is in a box somewhere and I just get a code for it. 04' though and that probably has something to do with it.
-sean- is offline
post #6 of 8 Old 06-11-2009, 09:32 AM Thread Starter
mlelah
Fuel pump gasket leak
so I took my jeep to the dealership and they did a smoke test. They said smoke is coming from the fuel pump area. They want $700 to replace the fuel pump module. No way since the fuel pump is fine. I think I just need to drop the tank and replace the ring gasket. Comments or suggestions? Thanks.
mlelah is offline
post #7 of 8 Old 06-11-2009, 07:37 PM
WahooCreek
I think you're right.
If you do a search using the codes and the fuel tank gasket, you should find what you are looking for - I recall seeing it when I was trying to find my leak.
Good luck.
post #8 of 8 Old 06-11-2009, 07:51 PM
WahooCreek
A couple of minutes of searching and found this for you:
http://www.jeepforum.com/forum/f9/code-p0455-82307/
Leak detection pump TheBoogieman TJ Wrangler Technical Forum 7 06-24-2009 11:51 AM
Leak detection pump three3fitty TJ Wrangler Technical Forum 4 01-20-2008 11:21 AM
leak detection pump 1CleanTJ TJ Wrangler Technical Forum 8 01-14-2008 04:44 AM
Leak Detection Pump problems magoat TJ Wrangler Technical Forum 5 03-14-2006 09:40 PM
Vapor Leak Detection Pump... Where is it on a 02? CEP TJ Wrangler Technical Forum 6 04-06-2005 11:05 AM
