Leak coming from where driveshaft enters rear differential - JeepForum.com
post #1 of 6 Old 09-25-2005, 11:33 AM Thread Starter
WheelinTJ2004
04 TJ
Is this common. I was bouncing around on some rocks...but don't think I hit the driveshaft. Is there anything specific that would have caused this?
WheelinTJ2004 is offline
post #2 of 6 Old 09-25-2005, 11:36 AM
got4-Lo
bad pinion seal....... not too hard to fix
stretched *** tj
got4-Lo is offline
post #3 of 6 Old 09-25-2005, 12:47 PM
AjRagno
Originally Posted by WheelinTJ2004
04 TJ
Driveline vibes will cause this. I saw from another one of your posts that you have a 2" lift, BL and MML. Make sure your driveline angles are correct.
Since you also have a Dana 44 and a 5-speed, like myself, even a 2" lift can cause vibes. If you go out and measure your drive shaft, you'll find it's only about 18 inches from the yoke to the tailshaft housing. A shaft this short will create ungraceful angles, even with a 2" lift.
AjRagno is offline
post #4 of 6 Old 09-25-2005, 12:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Good point. No amount of driveline vibrations are acceptable since they will eventually cause seal and/or bearing failures.
Jerry Bransford is online now
post #5 of 6 Old 09-25-2005, 04:35 PM Thread Starter
WheelinTJ2004
thanks all.
No vibes. I had them for about a week, about 3 months ago, but an allignment took care of that.
Will the dealer still honor the warrenty if I have the lift on there?
post #6 of 6 Old 09-25-2005, 06:06 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
wat else can cause it to go bad? i had a blown seal right after i bought mine replaced it and it blew again,
RnEmOvr is offline
Rear Differential Leak howellru YJ Wrangler Technical Forum 10 01-06-2015 04:26 PM
oil leaking our of rear driveshaft going into differential???? jonlanham TJ Wrangler Technical Forum 13 05-19-2009 09:52 AM
Leak where front shaft enters axle housing??? christrx450 TJ Wrangler Technical Forum 2 07-10-2008 09:12 AM
Rear Differential Leak Tufftoy TJ Wrangler Technical Forum 7 11-07-2007 07:41 PM
Rear differential leak rick95 YJ Wrangler Technical Forum 6 03-30-2006 06:36 PM
