LCA Eccentric Bolts - JeepForum.com
post #1 of 4 Old 10-05-2008, 04:43 PM Thread Starter
luvmusl
LCA Eccentric Bolts
While removing my D30one of these bolts sheared. I searched and found that these type bolts are exclusive to 97. True? I am adding RE LCA's and swapping in a Rubi D44. The mounts on the D44 look identical to those on the D30. Do I need to replace those bolts with new eccentric bolts? Or are some new grade 8's okay to use?
luvmusl is offline
post #2 of 4 Old 10-05-2008, 05:14 PM
LJameson
Those eccentric bolts adjust your Caster angle. Many people (inlcuding myself) buy those to adjust our angles instead of buying aftermarket control arms. You can get away with grade 8's, but i'm not sure if it'll set your caster angle at the correct specs. As for getting those bolts, the only place I know of that sells them is the stealership for about 24 bucks....for a stupid bolt.
1990 YJ
LJameson is offline
post #3 of 4 Old 10-05-2008, 07:54 PM Thread Starter
luvmusl
So is it true that 97 was the only year those were standard?
luvmusl is offline
post #4 of 4 Old 10-06-2008, 08:18 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yep. They are a cheap and slightly effective way to adjust your caster, but at the expense of damaging the control arm mounts.
There's really not enough clamping surface at the bolt sleeve to keep the mounts in place if you stress them.
The non eccentrics use the big round washer locked into the horseshoes to help somewhat. Slotted holes are a fairly poor system overall given how much stress the axle can see when you put on larger tires.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
Eccentric hardware is it needed CWD98TJ TJ Wrangler Technical Forum 1 10-21-2009 02:44 PM
Will eccentric bolt help alignment on 2005 X? techwriter73 TJ Wrangler Technical Forum 5 11-18-2008 12:24 PM
Eccentric cam bolts for rear driveshaft alignment xtremelx88 TJ Wrangler Technical Forum 9 06-04-2007 09:10 PM
Removal of snapped body mount bolts and bolts in general? SpedJeep YJ Wrangler Technical Forum 15 10-16-2005 09:01 PM
Eccentric Cam Bolts ? chrisvr6 TJ Wrangler Technical Forum 1 01-16-2005 08:21 PM
