Lazy Check Engine Light - JeepForum.com
post #1 of 8 Old 08-05-2008, 09:52 AM Thread Starter
TJ driver
How come my check engine light will not come on when I have a problem. It didn't come on the two seperate times I left the gas cap off. It didn't come on When my TCL quit working or when the tranny completely died a short time later. It never came on a little bit ago the jeep would sputter in the rain and once it about died on me going 35 mph but no CEL (that last problem was fixed by a new cap, rotor, and upstr. oxygen sensor). I guess my CEL can work because it stayed on for a day when I had my fuel pump replaced. Any body else ever have this problem?
98 4.0 L TJ (DD)
TJ driver is offline
post #2 of 8 Old 08-05-2008, 10:01 AM
the mad hatter
Isn't the CEL dependent on the vehicles sensors? So if a part goes out that has no sensor on it, your CEL probably wouldn't come on? Just a guess.
Maybe you need the CEL repaired?
'05 Jeep Wrangler X
'07 Jeep Patriot Limited
the mad hatter is offline
post #3 of 8 Old 08-05-2008, 10:20 AM Thread Starter
TJ driver
Well I was thinking that the engine about dying while going down the road would have sent some sort of code. Maybe I shuld purposly unplug something and see if it throws a CEL. also I always thought that the gas cap being loose (or off) would set off a code.
98 4.0 L TJ (DD)
post #4 of 8 Old 08-05-2008, 11:44 AM
jimaug87
You need to be driving for quite some time for the gas cap to throw a code.
I'd be a good idea to unplug a sensor (o2 or something) and see if your Jeep picks it up.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline
post #5 of 8 Old 08-05-2008, 11:50 AM
chickenwingsmmm
maby ur bulb is burnt out.
chickenwingsmmm is offline
post #6 of 8 Old 08-05-2008, 12:26 PM
Hotrod97z
Hotrod97z's Avatar
Have you installed a "Check Engine Light Eliminator"?
OK...Just kidding.
If your Jeep is a newer one ('00 or '01 or newer I've heard), trun the key ON-OFF-ON three times within 5 seconds to display the DTC on the odometer. If the CEL bulb is blown, there should be codes stored and will show up using this test. If no codes display, then bulb probably isn't blown.
Try unpluging the Engine Coolant Temperature sensor on the thermostat housing and crank it. I forgot to reconnect this the other day when I was changing my thermostat and the CEL came on immediately. Don't leave it off for a long time, just long enough to check you CEL.
Alan
'03 TJ
Hotrod97z is offline
post #7 of 8 Old 08-05-2008, 12:31 PM
Brown Dog
Vendor
Brown Dog's Avatar
There are certain codes that are not considered critical. For those, the CEL does not illuminate. It is assumed that when you service the vehicle, you will check the codes and repair those items. It is only items that cause serious emission problems, or problems with the operation of the vehicle that trip the CEL. Repair manuals talk about the specifics, and code charts show which are which.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #8 of 8 Old 08-06-2008, 02:17 PM Thread Starter
TJ driver
I know that the light isn't burned out since it comes on when I start it. When the jeep almost died in the rain I did the code check thing and it worked but didn't get any codes. Brown dog might be right about any of the codes not being critical.
98 4.0 L TJ (DD)
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 01:19 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 08:43 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 04:48 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
