Last minute lift and tire help - JeepForum.com
post #1 of 9 Old 07-21-2010, 09:41 AM Thread Starter
Rellyynn
im gettin 33x10.5 KM2s, the 3.25 suspenion lift from Rough Country, and 15x8 52 series from pro comp. Once all this stuff is installed on my car, what all effects will it have? Is there anything I need to change and/or fix? Will I need new brakes? What all am i going to need to fix my car for all this stuff to be on?
I just want to make sure i got everything right once im getting this stuff on.
Thanks so much.
Rellyynn is offline
post #2 of 9 Old 07-21-2010, 09:43 AM
JeepGuy813
wow, i never seen a car with a 3.25" suspension lift or some 33" km2's
JeepGuy813 is offline
post #3 of 9 Old 07-21-2010, 09:51 AM
LandoCommando
Its not a car.
You might need a transfer case drop as you may get vibes.
You will need an adjustable front trackbar to compensate for the axle shift that will occur from the lift.
Depending on the backspacing on your rims you may need spacers.
You may need longer brake lines.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline
post #4 of 9 Old 07-21-2010, 09:54 AM Thread Starter
Rellyynn
Originally Posted by LandoCommando View Post
Its not a car.
Thanks. This will be my main car, it will be on the streets far more than in the mud. I may occasionly take it mudding. But if this is just my street car, will i still need all the stuff you had listed before?
Rellyynn is offline
post #5 of 9 Old 07-21-2010, 10:02 AM
MO2500
You will get flamed here for calling your Jeep a car, be careful
You may need to address vibrations with a combination of a motor mount lift or t-case drop after the lift. You won't know if you have vibes until after you drive it. You may want to consider an adjustable track bar to re-center your axle after the lift. However it's not entirely necessary for a street jeep. Get the correct backspacing for your wheels and you won't need spacers. 4"-3.75" BS should work well
Instagram: @omsmike
MO2500 is offline
post #6 of 9 Old 07-21-2010, 10:18 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
It's not a car and it doesn't have a v6 either.Ditch the large t case drop supplied and do a MML for vibes.I had that lift on my JEEP with a BL/MML and 35's.
TheBoogieman is offline
post #7 of 9 Old 07-21-2010, 03:34 PM Thread Starter
Rellyynn
on the 3.25 RC suspension lift it comes with (4) RCX Performance 2.2 series shocks, Front: 2.5" progressive rate coil springs, 0.75" poly isolater spacers, sway-bar links, and transfer case drop kit.
Rear: 2.5" progressive rate coil springs, 0.75" poly isolater spacers, sway-bar links, and track bar drop bracket.
is there anything else i need to add so i can have everything right? and how much do yall think it would cost to get a new break line?
Rellyynn is offline
post #8 of 9 Old 07-21-2010, 05:52 PM
TheBoogieman
Deeply Disturbed
You can use the t case drop or get a 1" MML like I did.Why do you need a new brake line?Longer YJ lines will fit.
post #9 of 9 Old 07-24-2010, 09:54 AM Thread Starter
Rellyynn
I read that if i were to get over than a 3" lift, ide need a new break line. But now i dont think i will, alot of people has said that i wont need one. But i do think the RC 3.25 suspension lift does come with a t case drop
Rellyynn is offline
km2 , pro comp , rough country , TJ
Lift kit is here! Last minute questions.. 05LjNj TJ Wrangler Technical Forum 10 06-25-2009 06:11 PM
Lift going in last minute questions.... IH8ROADZ TJ Wrangler Technical Forum 12 03-15-2008 09:00 AM
About to go through with first lift... Any last minute advice??? CityJeep TJ Wrangler Technical Forum 9 06-20-2005 09:17 PM
Last minute question before installing my lift... boomhower YJ Wrangler Technical Forum 5 03-16-2005 05:48 PM
Last Minute Lift Advice! Sandibar TJ Wrangler Technical Forum 10 10-03-2003 12:57 PM
