Largest tires on a stock TJ? W/O lift - Page 2 - JeepForum.com
post #16 of 40 Old 12-15-2011, 02:25 PM
SBpunk
Google..... http://www.jeepfan.com/tech/what-tires-fit/
2004 Jeep WJ Overland
1992 Jeep MJ 4x4 5 speed
SBpunk is offline
post #17 of 40 Old 02-03-2013, 04:53 PM
bigrl14
hey guys. im new to the forum and i was just wondering, whats the biggest lift i can put on my 98 tj without changing any gearing or anything major like that. thanks.
bigrl14 is offline
post #18 of 40 Old 02-03-2013, 05:17 PM
Kodiak17
Google does wonders. Lift kits don't affect your gearing, tires do.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #19 of 40 Old 02-03-2013, 05:21 PM
BuckshotTJ01
My buddy has 32's but rubs on stock finders. If you want 32's on stock suspension get after market flares.
BuckshotTJ01 is offline
post #20 of 40 Old 02-03-2013, 05:27 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Try searching. And stickies.
2011 Billet JKUS
Jackal01 is offline
post #21 of 40 Old 02-03-2013, 05:36 PM
threeb
Can't someone just say 31s and move on? Oops i just did.
LJ Owners Group member #431.
threeb is offline
post #22 of 40 Old 02-03-2013, 06:31 PM
MotoSoul
There were a few that mentioned 31's being the proper limit. Unfortunately there are usually fewer that will listen.
I will state for the record that if you have a hard time paying for the tires then you won't be able to afford the extra's they require. I am not even talking about the upgrades to fit them either as gas is not so cheap these days.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline
post #23 of 40 Old 02-03-2013, 06:38 PM
pmcjeep
2in lift and 31s.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #24 of 40 Old 02-03-2013, 06:40 PM
Kodiak17
This thread was revived from a year ago.. but asking a different question. No sense in posting about the original topic.
Kodiak17 is offline
post #25 of 40 Old 02-03-2013, 07:01 PM
tyvanwie
Originally Posted by pmcjeep View Post
2in lift and 31s.
Not true. You can put a 7" lift and 31s.
tyvanwie is offline
post #26 of 40 Old 02-03-2013, 07:44 PM
MotoSoul
That is a very good point lol. I might have caught that if I was on a PC. You are right though a two in suspension lift and a one inch body lift is aoutabout the cheapest way you can go.
MotoSoul is offline
post #27 of 40 Old 02-03-2013, 08:34 PM
lax22
Stock sahara on 32s no rubbing on the street.
Current Jeeps
04 Rubicon
lax22 is offline
post #28 of 40 Old 02-03-2013, 09:29 PM
threeb
Pics of bottom lip of flare.
threeb is offline
post #29 of 40 Old 02-03-2013, 11:06 PM
WeezyBlue
I rubbed the paint off the spring perches disco'd with 31x10.5 on my stock '06 SE. I seem to be one of the only people that has experienced that on this forum. 31x10.5 definitely did not fit. 31x9.5, if anybody makes it, would be fine regardless of factory wheels
KD8UCX
CURRENT: '05 TJ Rubicon
Past: '06 TJ SE
WeezyBlue is offline
post #30 of 40 Old 02-04-2013, 07:51 AM
RowJ
Early Sahara TJ's had painted flares? That 99 (above) is the first one I've seen.
RJ
RowJ is offline
largest , stock , tires , tj , wheels
what are the largest tires i can fit on a stock YJ Xzero117 YJ Wrangler Technical Forum 4 09-02-2008 04:48 PM
Largest tires on a stock 01 TJ? joppermann TJ Wrangler Technical Forum 27 04-12-2007 07:43 PM
Largest Tires on a Stock X CapnDik JK Wrangler Technical Forum 7 10-28-2006 10:22 AM
Largest Tires On Stock 03 Tj jbpdog TJ Wrangler Technical Forum 6 07-13-2005 04:00 PM
largest tires w/ stock suspension Krenshaw04 TJ Wrangler Technical Forum 7 08-18-2004 04:39 PM
