largest tire size? - JeepForum.com
post #1 of 33 Old 10-11-2006, 04:39 PM Thread Starter
Trebor
largest tire size?
what is the largest tire size (that is fully functional) that can fit on my stock (premium wheel package) rims? they came with 30 x 9.5's on them and i have about 52k on them so far. i had planned on running them bald but toady i ran into a little snag a quarter inch thick piece of metal shapped like a dorrito of approxamatly the same size. needless to say i am now down one tire and considering upgradding tires only i would consider a lift or acos system so they can fit. what have you guys done out there? thanks for the help in advance oh yea it's a 05 unlimited with the upgradded wheel and tire package stock. thanks for any help. and let the heckling begin.
Trebor is offline
post #2 of 33 Old 10-11-2006, 04:42 PM
momomike3
If you want to UPGRADE... get a Budget Boost and a Body lift and you can fit 33's. 31's will fit stock. I think unlimiteds look amazing with 33's+.
momomike3 is offline
post #3 of 33 Old 10-11-2006, 04:43 PM Thread Starter
Trebor
is it ok to put 33's on a stock rim?
Trebor is offline
post #4 of 33 Old 10-11-2006, 05:48 PM
SecondTJ
SecondTJ's Avatar
your not going to be able to fit a very wide 33 on the stock rim, its only 7" wide. you can fit pizza cutter 33x10.5
but the biggest tire you can run is a 31" on stock suspension setup, even with them you will get some rubbing when the wheel is turned all the way, but its a easy fix, just need some washers
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #5 of 33 Old 10-11-2006, 05:55 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
ACOS will do fine for a 33 or 32 tire... i think theyre like 3.25" total height, so a 33 will fit, but you might loose some functionablilty/flex.
Tire wise i put a 305/70R16 on a 6.5" wheel on my K2500, the main thing you will have problems with is BS... You can buy some after market wheels for cheep if that's an option, or just buy some wheel spacers.
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #6 of 33 Old 10-11-2006, 06:03 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Without lifting your Jeep, 31x10.50 is the largest tire size that will fit without excessive rub. You can use your stock wheels with that tire size.
Jerry Bransford is online now
post #7 of 33 Old 10-11-2006, 06:08 PM
Nine Mile
Junior Member
Seen people do 32's but it's pretty non-functional unless you trim a bunch.
Listen to Jerry B. -- 31's are what you probably want.
Nine Mile is offline
post #8 of 33 Old 10-11-2006, 06:30 PM Thread Starter
Trebor
I mean it came with 30 x9.5's on it, your telling me i only have an inch to play with? if i do a 1 inch body lift can i fit 33's then? thanks for all your help guys i really appreciate it like the story goes i've had ruff day.
Trebor is offline
post #9 of 33 Old 10-11-2006, 06:32 PM Thread Starter
Trebor
10.5 is cool i'm talking about the tire height.
Trebor is offline
post #10 of 33 Old 10-11-2006, 06:33 PM
Jakemd98
Jakemd98's Avatar
you can fit them... but it would be really tight and def. not recomended. if you really want the 33's then do a BB and a BL.
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Jakemd98 is offline
post #11 of 33 Old 10-11-2006, 06:33 PM
daveg13
daveg13's Avatar
Yep, 31X10.5 is the largest stock.
'99 Sport
31X10.5-15 BFG AT, some Tuffy boxes, slowly being built.
daveg13 is offline
post #12 of 33 Old 10-11-2006, 06:40 PM
Bud in Texas
I just put the 31 x 10.50 BFG AT/KOs on my stocker. There's plenty of heighth clearance for normal driving. It's not the tall that gets you; it's the wide. I had stock 15 x 8 wheels and my tires don't rub at full turn but there's less than 1/4" clearance to the "frame". If I drop the air pressure, it may be an issue. Even at that, I can correct it with 20 cents worth of washers.
Bud in Texas is offline
post #13 of 33 Old 10-11-2006, 06:41 PM Thread Starter
Trebor
what is BB and BL i'm guessing body lift? and if so i still have no idea what BB is.
Trebor is offline
post #14 of 33 Old 10-11-2006, 06:43 PM
SecondTJ
SecondTJ's Avatar
yes, BL is body lift
BB is Budget Boost.
most common around here is the RE (rubicon express), it includes 2" coil spacers and shocks. and rear bumpstop extensions. All for about $225
SecondTJ is offline
post #15 of 33 Old 10-11-2006, 06:45 PM Thread Starter
Trebor
thanks for clearing that up....so if i did a 1 inch body lift what would that get me? i'm not ready to do a sus. lift yet because i put to many highway miles on the thing right now. 50K+ 18 months so far. you guys are awsome it's like an encylopedia for jeeps around here.
Trebor is offline
largest tire size for an 06 X policetech TJ Wrangler Technical Forum 21 07-13-2009 11:55 AM
Largest size tire on a stock yj nas4792 YJ Wrangler Technical Forum 14 05-21-2008 05:55 PM
what's the largest size tire put on a stock yj nas4792 YJ Wrangler Technical Forum 7 05-21-2008 06:56 AM
Largest spare tire size???? bluejeepjeep TJ Wrangler Technical Forum 10 04-09-2007 09:50 AM
D44's largest tire size djXternal TJ Wrangler Technical Forum 26 10-28-2006 03:23 PM
