Largest Tire on a Rubicon "Moab" Wheel? - JeepForum.com
post #1 of 4 Old 12-23-2004, 01:22 PM Thread Starter
SteelBlueTJ
What is the largest tire size I can get on a stock rubicon rim with no lifts of any kind? I am thinking about getting the rubi rims for my stock '99 Sport but was just wondering how big I can go before lifting. Thanks
SteelBlueTJ is offline
post #2 of 4 Old 12-23-2004, 01:55 PM
AmberFireTJ
You are not going to want to get anything bigger than 31 inches. With a 2" BB you could clear 32's with minimal rubbing. If you added 3" of lift (ie: 2" BB and a 1" Body Lift) you could clear 33" tires.
Some people might try to tell you that you could run 32-33" tires on stock suspension, while possible, you will be rubbing your flares like crazy with any flex in the suspension.
Don't forget that the Moab wheels have 5" of backspacing so you may need to add wheel spacers if you use a tire wider than 10.5". Hope this helps, you can also try a search for more answers.
AmberFireTJ is offline
post #3 of 4 Old 12-23-2004, 02:11 PM
Jeepxj96
Jeepxj96's Avatar
You may have already been told this, But if you have just ignore it. You can try looking on Rubicon Owners forum for some answers.
Rubicon Owners Forum
Bob
1996 Land Rover Discovery with a bunch of stuff on super swampers
Jeepxj96 is offline
post #4 of 4 Old 12-23-2004, 05:46 PM
DazedRangerFred
i think i heard that the largest tire that people would recommend putting on the moab rim was 35, but for the stock lift hit i would stay with the 31 at most
2004 Rubicon
Electric Lime Green
RE 5.5 LA and 35's, TxT front Bumper, Jeeperman Rear Bumper/ Tire Carrier
DazedRangerFred is offline
largest tire size on stock 17" rubicon wheel? MEinSoCal JK Wrangler Technical Forum 15 09-01-2012 10:23 PM
largest tire on stock jk 16" wheel? smokin1 JK Wrangler Technical Forum 16 04-05-2010 05:59 PM
What's the largest and tallest "street" tire that can be put on a stock 09 4-door X vmania JK Wrangler Technical Forum 12 12-27-2008 10:22 AM
265s largest tire for the Sahara's 18" wheel? TwinsJeep JK Wrangler Technical Forum 5 01-04-2007 02:39 PM
rubicon "moab" wheels numchuck TJ Wrangler Technical Forum 3 12-15-2004 12:54 PM
