Lange Hoist-A-Top Hard Top Remover - JeepForum.com
post #1 of 5 Old 04-08-2005, 09:49 AM Thread Starter
wrangler2002
Has anyone used this product before. It uses a hoist to allow one person to remove a hard top...
Is it junk or does it work well?
http://www.4wd.com/shop/productdetai...ductsku=014388
wrangler2002 is offline
post #2 of 5 Old 04-08-2005, 10:38 AM
Tirith
I've been using that model for over 2 years now. Works great, very simple. I use it with a come-along. The hooks attach under the edge of the roof of the hard top, not the base, so there is no problem with the sides spreading apart over time.
The only complaints I have are minor. First, the rear lift glass must be open to use the rear hook. And second, you have to have it perfectly balanced, or else it hangs cockeyed.
Tirith is offline
post #3 of 5 Old 04-08-2005, 10:45 AM
R Newman
I use one with a cheap Harbor Freight electric winch, works great 1-man operation.
R Newman is offline
post #4 of 5 Old 04-08-2005, 10:48 AM
Gritz
Gritz's Avatar
Run your straps front to back w/2 anchor points=no spinning
Here's mine: under $60 it's the first album.
http://photos.yahoo.com/bgritz
gritz
Gritz is offline
post #5 of 5 Old 04-08-2005, 01:51 PM
Dave Taylor
Dave Taylor's Avatar
I bought my hardtop hoist (a 440 lber) from Harbor Freight for $59 flat (free shipping on orders over $50)
Can't beat it for running the 140 lb hardtop up and down.
For storage; I screwed 4 eye-bolts into the floor-beams above the garage; and ran 4 ratchet-straps down from them to hold the top. The hoist doesn't hold anything in the offseason...all it does it run the top up and down; once a year.
Nashville, TN (Franklin)
Lon. 86'54.285' W
Lat. 35'58.310' N
Alt. 610'
Dave Taylor is offline
Storing hardtop on Lange hardtop hoist? TJDaveX Wrangler General Discussion 4 06-29-2009 11:20 AM
Lange Power Hoist 1911lover JK Wrangler Technical Forum 3 05-12-2008 09:06 AM
Lange Hoist-a-top specs? RedRockN JK Wrangler Technical Forum 2 06-10-2007 08:00 PM
Lange Hoist tales TJ Wrangler Technical Forum 0 04-15-2007 03:40 PM
Here's my hard top hoist: JPJeep TJ Wrangler Technical Forum 7 06-11-2002 04:40 PM
