L.E.D. dome and floor light help - JeepForum.com
post #1 of 21 Old 04-02-2011, 03:02 PM Thread Starter
tjallday
I'm thinking of replacing the bulbs with LED bulbs in both the dome and the floor if that is possible with my 97. Could someone who has done it point me in the right direction.
tjallday is offline
post #2 of 21 Old 04-02-2011, 03:08 PM
freeskier93
Lucky for you I have a '97 and have done this already and saved all the info for future use:
Bulbs:
Interior-
Dash/HVAC Controls: LED 74
Courtesy Lamps, Under Dash: Bulb 89/LED 67
Dome Light: Bulb 912/LED 921/T13
Exterior-
Backup/Reverse: Bulb/LED1156
Stop/Turn: LED 1157
Front Turn: LED 3157
Side Markers: Bulb 168/LED WLED Miniature wedge bulb
Headlights: H 6024
I use http://www.superbrightleds.com, they are top notch and their site is much easier to use than v-leds.com. This link will also help: http://www.superbrightleds.com/bulb_cross.php. Click on the links in the left column from the info I gave you to take you to the exact LED.
freeskier93 is offline
post #3 of 21 Old 04-02-2011, 07:33 PM Thread Starter
tjallday
thanks a lot!!!
tjallday is offline
post #4 of 21 Old 04-02-2011, 08:46 PM Thread Starter
tjallday
Don't you need a flasher box for the led turn signals?? And does it matter what length the bulbs for dome and courtesy lights are. Also how does the dome light open up, with a screw driver?
Thanks I appreciate it!
tjallday is offline
post #5 of 21 Old 04-02-2011, 09:57 PM
freeskier93
You don't need a new flasher. You can do the flasher mod on stu's website. Length doesn't matter, as long as it's one of the WLEDs it will fit the dome light and one of the 1157 tail lights for the courtesy lights. Flat head screwdriver to pop the cover off.
Warning about about the dome light, the bulb is mounted vertically, and as you may know LEDs are directional and aren't 360 degrees. It pretty much just shines the straight to the side and not down. I've been trying to think of a different way to do it with all the little LED doodads on their site.
post #6 of 21 Old 04-02-2011, 10:10 PM
inglisleslie
Way better dome idea. Warm white led color
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #7 of 21 Old 04-02-2011, 10:23 PM
vanillathrilla
I've been wanting to upgrade my interior lighting too--beyond just the gauges. There's not enough light on the inside when I need it, so I'm hoping to do something like the above with a big grid of LED's in the dome... and either accent lighting under the dash with the courtesy lights or maybe "mood lighting"
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #8 of 21 Old 04-02-2011, 10:30 PM
freeskier93
How does it connect? I figured I might just get a panel like that and splice it in.
post #9 of 21 Old 04-03-2011, 09:52 AM Thread Starter
tjallday
the site has 360 degree bulbs that would seem to fit. They are wleds.
tjallday is offline
post #10 of 21 Old 04-03-2011, 09:57 AM
biffgnar
biffgnar's Avatar
The ones like that in my dome lights came with an adapter that fits into the plug that is there.
Romney in 2020!
biffgnar is offline
post #11 of 21 Old 04-03-2011, 10:31 AM
vanillathrilla
How do you attach it? Double sided tape?
Can you try and get a picture illustrating how much light it actually gives off in the dark? If at all possible, of course.. You happy with it?
post #12 of 21 Old 04-03-2011, 10:36 AM
biffgnar
biffgnar's Avatar
Yep, double sided tape. Will have to try to take picture tonight. I'm happy.
Romney in 2020!
biffgnar is offline
post #13 of 21 Old 05-16-2011, 07:17 AM
bobdog
This sounds dumb, I know, but I was attempting to remove the cover from my dome light, and it just pulled the light itself down out of the sound bar. How do you take the cover off of the dome light. Obviously I'm too dumb to figure it out.
Black Jeep Society
New Mexico Jeep Club
Atheist Jeep Society
Micro-Trailer Club
bobdog is offline
post #14 of 21 Old 05-16-2011, 02:04 PM
vanillathrilla
I'm pretty sure it [the cover] prys/pops off!?!
post #15 of 21 Old 11-04-2015, 07:57 PM
vanillathrilla
I can't seem to find the correct bulb replacement for the dome light... The bulb referenced in this thread doesn't look right.
dome light , LED lights
Dome light napajeep JK Wrangler Technical Forum 4 12-02-2010 01:46 PM
dome/interior Light and headlight chime linked to seat belt light? Redryan98 TJ Wrangler Technical Forum 8 09-09-2010 08:25 AM
no dome light coal1cracker Wrangler General Discussion 3 01-22-2010 01:05 PM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 07:47 AM
Replacing dome light & LED floor light question MacK JK Wrangler Technical Forum 7 09-30-2008 01:02 PM
