KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift.
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l50% Off Sale at KrawlOff-Road.comTactical Recovery Equipment Soft Shackles!!!
Unread 12-22-2008, 03:51 PM   #76
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by gribbles View Post
mud, where did you relocate the washer fluid bottle on the jeep with the manual tranny?
it ended up with a bottle from a 82 chev pu. next to the master cyl. I also drilled it with a hole saw to put the rear washer pump in. I don't think I have a pic of that, I'll check later.
I saw another thread someone put it next to the dip stick on a bracket mounted off the motor mount if memory serves...
here's white99tj's pic and thread...
http://www.jeepforum.com/forum/f9/another-lcg-hiline-hood-mid-arms-593280/
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 12-29-2008, 08:49 AM   #77
RubiRock
thanks for pointing me over to this thread, mudb8!
cant wait to start cutting/raising my hood and fenders
'04 Rubi - For Sale
01.5 S4
RubiRock is offline   Reply With Quote Quick reply to this message
Unread 12-29-2008, 10:36 AM   #78
mudb8
mudb8's Avatar
Unread 01-21-2009, 07:05 PM   #79
mudb8
mudb8's Avatar
well, I found a few 97-98 ford winstar air boxes, I haven't looked at the explorer boxes yet, I've been told they are the same or similar.
I've got em shortened and ready to be installed.
I still haven't gotten around to making it a "cold air" from the cowl yet, tho I can say it got rid of the stinkin noise from the hacked off factory box and cone type filters...
u-pull-it special..
hacking it up...
fine tuning....
putting it back together..
Unread 01-21-2009, 07:09 PM   #80
mudb8
mudb8's Avatar
finished..
intake side..
box to tb...
installed pics later when I get around to it!
Unread 01-31-2009, 07:58 AM   #81
ftgiles
Have you finished the filter relocation yet? Pics?
ftgiles is offline   Reply With Quote Quick reply to this message
Unread 01-31-2009, 08:55 AM   #82
nriver
2011 JK Wrangler
Nice work, seen your posts on CL in portland.
I was going to comment on moving the evap canister, I have done the same thing to the rear and just removed the canister. That gave enough room for the 37s. You also cut more of the rear tub than I did, but I may cut more in the future as needed, none yet.
My 37s stuffed in the rear.
I did do tubes up front.
All on OME springs at the time. I have changed out springs now, so working out some new interference issues.
not trying to hijack.
nriver is offline   Reply With Quote Quick reply to this message
Unread 01-31-2009, 04:49 PM   #83
neverbackdown
hey nriver do you have a picture of your whole jeep?
'History will be kind to me for I intend to write it."
-Sir Winston Churchill
neverbackdown is offline   Reply With Quote Quick reply to this message
Unread 01-31-2009, 08:32 PM   #84
mudb8
mudb8's Avatar
na, I still haven't finished it yet, just haven't had any time, tho I do have it under the hood being used, It got rid of the noise from the open filter.
my track bar is still laying on the floor in the kitchen also.
Unread 01-31-2009, 08:43 PM   #85
mudb8
mudb8's Avatar
sweet, highline those tube fenders, that'll give ya another 3.25", I could help ya trim the hood if ya want, I've done a few so it's pretty much nothing to me to start hacking it off with the grinder.
for the rear you could just trim the flares to get rid of the rub, or just move em up also. I cut out as much as I did to run 37's with 2" or less bumpstops in the rear and no body lift.
I'm actually planning to keep my evap can, just gonna move it between the rear diff and the t-case attatched to the tub.
Unread 02-01-2009, 03:14 PM   #86
nriver
2011 JK Wrangler
I actually have enough room and up travel to not need to highline the tubes. They dont have a tube along the body line (for lack of a different term). The tire can go all the way up to the sheet metal. They also have a enlarged wheel well opening and allow for the 37s there with no issues.
I just took off my 4" springs and put the stock Rubicon springs in. I think I am going to run the jeep this way. Looks like everything will fit. I may need to trim the rear tub a bit.
As far as bumpstops, I ran stock bumpstops up front in the picture above. I dont plan on adding any front bumpstops. I need to modify the front track bar mount to not contact the diff cover. I will have that done soon.
Rear bumpstops are a extra 2" poly stops, that might change soon as well. Need to do some flexing with the new triangulation setup there and stock springs.
I may end up with a 1" BB front or rear to level it out. Cant remember now what way it needs to go.
Not trying to hijack your thread. I like the idea of free mods.
as for a pic, here are a couple
I guess these are poser shots.
Unread 02-23-2009, 11:33 PM   #87
mudb8
mudb8's Avatar
here's the getting around to a pic of th air box temporary install. it'll be in the cowl when it's done...
Unread 02-23-2009, 11:37 PM   #88
mudb8
mudb8's Avatar
another option i ran across... this is a 99 escort air box. same filter just a different air horn... in the pic I put the air horn off of a 98 winstar on the 99 escort to check the fitment still installed in the escort.. I've found in u-pull- it yards, hardly any of the rigs have a complete box so ya gotta search for parts to put together a complete unit..
Unread 03-31-2009, 03:52 PM   #89
rroadkilll
Plan on doing this next month!!!
Originally Posted by B2CARPEN
I can't wait to tear it up in the mall parking lot with you some day Jay... we could park on each other's tires all flexed out taking up 4 parking spots, walk in the mall with our jeep keys dangling for everyone to see, hit up some abercrombie and fitch, then go back outside and hang out by the jeeps for a few hours... maybe get risky and drive over some curbs.. :highfive:
rroadkilll is offline   Reply With Quote Quick reply to this message
Unread 03-31-2009, 08:43 PM   #90
mudb8
mudb8's Avatar
feel free to ask questions, I pretty much have the brackets perfected..
