KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift.
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-20-2008, 02:08 PM   #61
gribbles
I assume you will be making your own rocker guards, when you do will you be compensating for the gaps that raising the fenders left?
IndyORV
My Jeep
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline   Reply With Quote Quick reply to this message
Unread 12-20-2008, 02:48 PM   #62
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by gribbles View Post
I'm running poison spider tube fenders and one of these days I am gonna get brave and do this myself...it looks sweet, I just REALLY don't wanna mess it up! I think the tubes would look sweet highlined...too bad you weren't in the midwest....
yeah, the spider tubes would look awesome.
I have started on rocker gaurds to cover the gap and protect the flare from snaging. snaging was a big problem for me before they were raised.
so far, I've hacked up some 1.5x3" 3/16" tube for the rocker duty. they'll be secured by the body bolts and the tub below the doors. haven't had the time to finish em yet.
it'll look kinda like the cj-7 trim bar, only larger and it wont ding.
something else I've thought of doing is build a bolt on steel fender gaurd/tube flares for the front to retain the stock turn signals, then the front of the stock fender could be hacked off and the gaurd would fit the higher grill contour, it would take a good hit to bend it unlike the stock fenders that wrinkle at the site of an oncoming tree.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2008, 03:55 PM   #63
neverbackdown
so mudb8 right now i have a 4" lift with 33" if i did the trim what tire sizes would i be looking at? 38"s ?
'History will be kind to me for I intend to write it."
-Sir Winston Churchill
neverbackdown is offline   Reply With Quote Quick reply to this message
Unread 12-20-2008, 03:56 PM   #64
gribbles
I am very interested in seeing both of these. as far as the fenders go, you should fab up a front grill hoop/tube fenders tied into each other, this would be sweet, you would have some killer strength then.
I like the idea of rocker guards that are similar to the ww2ww rockers, but have some steel to fill in the gap between the rocker and the fender to make it solid, so i wouldnt risk the chance of bending it or getting hung up on something (and to make it aesthetically pleasing) I don't have the fab skills to do this, but let me tell you, in my head it looks awesome
crawling this thread, looking forward to more updates
IndyORV
My Jeep
2007 WK CRD
Unread 12-20-2008, 08:07 PM   #65
mudb8
mudb8's Avatar
yeah, ya could run 38's with some more bumpstop up front and rear, provided ya currently have 2" over stock stops or a body lift, not exactly sure of what backspacing would be needed, I know with 37's and 15x8-3.5"bs they touch the shock tower fully stuffed and slightly rub the factory sway bar while turning. 2" bumpstops work great for 37's.
another thing, the evap can needs to be relocated for 37 and larger, I didn't move it, I put in an extra inch bumpstop to keep the tire from rubbing the bottom of it. if I had more time it would have been relocated to the underbody or separated from the char filter.
IMO 37's are all about all ya wanna run on the jeep axles, reasons being gearing and durability, I put 5.13's in the gold rubi to run with the 5sp, it seems to be a good combo.. at least the guy likes how it performs. I'm having a hard time resiting the notion of 39.5's actually, If i did the performance and driveability would stink.
couple more pics on 3.5" and 37" mtr's
Unread 12-20-2008, 08:12 PM   #66
mudb8
mudb8's Avatar
I hadn't thought of the hoop, but I have visions of it now!
I think ti would need to bolt on tho...
Unread 12-20-2008, 08:31 PM   #67
Kenbo-Slice
Uh oh..... You may have given me the itch! Too bad your on the complete other side of the country! I guess that I have to do it myself! Worst comes to worst... I mess up my fenders and HAVE to make myself some tube fenders to replace em'!! It looks real nice man! Good job!!
Kenbo-Slice is offline   Reply With Quote Quick reply to this message
Unread 12-20-2008, 08:35 PM   #68
mudb8
mudb8's Avatar
LOL, it was ich that lasted me about 6 months, both my fenders were bent up so I finally just did it, now I'm not afraid of tackling a set of perfect ones..
Unread 12-20-2008, 08:50 PM   #69
Kenbo-Slice
Hell mines a '98.... I LOVE "reasons" to upgrade. I just turned 60,000 miles so I guess its still new enough..... Then again it IS almost 11 years old, and what fun is looking the same as everyone else?
Unread 12-20-2008, 08:53 PM   #70
mudb8
mudb8's Avatar
Unread 12-21-2008, 10:39 AM   #71
neverbackdown
IMO 37's are all about all ya wanna run on the jeep axles, reasons being gearing and durability, I put 5.13's in the gold rubi to run with the 5sp, it seems to be a good combo.. at least the guy likes how it performs. I'm having a hard time resiting the notion of 39.5's actually, If i did the performance and drivability would stink.
i very aware of the weakness of the D35 and D30. i have been junk yard hunting in the mean time looking for maybe a nice 1 ton set up. who knows
Unread 12-21-2008, 11:12 AM   #72
mudb8
mudb8's Avatar
I'm trying hard to build the rubi without going beyond it's capabilties I can't afford a spendy build either.. so putting a ton of money into a d60/9"/10.5 or 9.5sf combo isn't an option even tho I have em.
here's a peak at my personal collection at the house..
Unread 12-21-2008, 12:14 PM   #73
1CleanTJ
nice seeing another homemade hignline on JF, We should start homemade highline club here
heres mine if ya never seen it
1CleanTJ is offline   Reply With Quote Quick reply to this message
Unread 12-21-2008, 05:42 PM   #74
mudb8
mudb8's Avatar
Yeah, Buddy! theres definately a few of few of us now...
Unread 12-22-2008, 11:33 AM   #75
gribbles
mud, where did you relocate the washer fluid bottle on the jeep with the manual tranny?
IndyORV
My Jeep
2007 WK CRD
