KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift.
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-12-2011, 03:50 AM   #196
Tylerzap
My 98 XJ "Zap" Build Thread
http://www.jeepforum.com/forum/f22/zap-98-xj-build-1462622/
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline   Reply With Quote Quick reply to this message
Unread 12-08-2011, 11:15 AM   #197
geiman
Looks awesome, might have to do this soon since it doesn't really cost anything! One question: it looks like you just cut the hood and leave it, is that right? I wasn't sure if you cut and then bent the edge or just left it.
geiman is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 12:21 AM   #198
mudb8
want it rite or rite now?
mudb8's Avatar
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 02:21 AM   #199
SKIN
What are you doing to your tires? Sipe'ing them?
SKIN is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 02:30 AM   #200
alienator
I think is about better grip
alienator is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 05:27 AM   #201
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Rear 3 link?
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 09:11 AM   #202
biffgnar
biffgnar's Avatar
Note the extra grooves in the pictures. Taking out a lot more rubber than just cutting for siping.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 09:17 AM   #203
rchase559
Grooving.
One reason to do it is to get a more desirable tread pattern. Another is to add some life into a worn out set by cutting the tread deeper.
Obviously the later has some ramifications such as decreasing the puncture resistance of the tire. Most people I know who groove for more tread depth do so on tires that are only seeing the trail.
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2014, 10:23 AM   #204
mudb8
mudb8's Avatar
Originally Posted by MisfitSeven View Post
Rear 3 link?
Front and rear.
9" separation @ the rear axle, front is still stock @ the axle, i just grew tired of the nose dive while braking and tossed in the upper to get rid of it.
Unread 01-26-2014, 10:27 AM   #205
mudb8
mudb8's Avatar
The 37" claws are take offs from a dodge with a bad alignment. After cutting them the jeep is actually driveable.
Todd says, "hey! Now we have geo-claws"... Lol
Made a huge differnce in traction a.d driveabilty.
Unread 01-26-2014, 03:16 PM   #206
MisfitSeven
MAiL Crawler.
They do look like the Yokohama Geolander mud terrains.
Mail crawling.
Unread 01-31-2014, 07:35 PM   #207
mudb8
mudb8's Avatar
Cant wait to get started on this...
Unread 02-12-2014, 12:36 PM   #208
Matt Graham
x2?
Instagram: @mattgraham79 - http://instagram.com/mattgraham79
Youtube: http://goo.gl/ar21Wp
Matt Graham is offline   Reply With Quote Quick reply to this message
Unread 02-12-2014, 12:39 PM   #209
geiman
Originally Posted by Matt Graham View Post
x2?
Once you cut, you can trim the hood with this:
http://www.rokmen.com/all-products-1...edge-trim.html
Unread 02-12-2014, 01:45 PM   #210
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by mudb8 View Post
Front and rear.
what length arms are you running front and rear, uppers and lowers? what front UCA mounts are you running on the frame side? looks like you cut off the frame side LCA mounts and just moved them?
and ORIs
Unlimited04 is offline   Reply With Quote Quick reply to this message
