KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - Page 7 - JeepForum.com
post #91 of 339 Old 03-31-2009, 09:51 PM
rroadkilll
I will...
I'll probably ask for your # too...
Originally Posted by B2CARPEN
I can't wait to tear it up in the mall parking lot with you some day Jay... we could park on each other's tires all flexed out taking up 4 parking spots, walk in the mall with our jeep keys dangling for everyone to see, hit up some abercrombie and fitch, then go back outside and hang out by the jeeps for a few hours... maybe get risky and drive over some curbs.. :highfive:
rroadkilll is offline
post #92 of 339 Old 03-31-2009, 10:03 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by rroadkilll View Post
I will...
the instant messengers are always on, I'm just not always sitting in front of it..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #93 of 339 Old 03-31-2009, 10:07 PM
wmeyer116
awesome man. nice job
Originally Posted by never monday View Post
Marcus,
Leave your inbred childish comments somewhere else. They are not welcome on JF
wmeyer116 is offline
post #94 of 339 Old 04-10-2009, 05:11 PM
rroadkilll
What Items did you need???
I'm trying to make the list and get the stuff so I can do this in 2 weeks!!!
post #95 of 339 Old 04-10-2009, 10:02 PM Thread Starter
mudb8
mudb8's Avatar
it'll vary through the years...
basics are a couple 3" long 3/8 bolts, nuts and large washers for the new top bolt of the fenders where they bolt to the grill.
1/4" bolts, nuts and 1 1/2" fender washers for the rear flares,
a 10 pack of 4 1/2" cuttoff wheels for the 4 1/2" angle grinder.
a 16" long piece of 1/8"x 2" or larger angle iron for the battery box and fender brackets.
mudb8 is offline
post #96 of 339 Old 04-11-2009, 06:27 AM
rroadkilll
PM me your number?
What/Pics for the angle iron???
post #97 of 339 Old 04-11-2009, 11:19 AM Thread Starter
mudb8
mudb8's Avatar
the angle iron is for the rear, lower front fender brackets. it's much easier to refit the tray by cutting the back side off rather than the front of the bracket. weld a stick of angle iron to the lower section that's cut off and bolt it all back on using the factory location.
mudb8 is offline
post #98 of 339 Old 04-20-2009, 01:56 AM Thread Starter
mudb8
mudb8's Avatar
LCG shock relocation....
I spent the better part of the day messng with these today..
having only a 2.5" lift and long travel shocks takes away uptravel from the suspension system.
I built the brackets to gain uptravel without sacrificing downtravel/flex
I have been running on 25.5" long 10" travel shocks which require 2+" bumpstops and limited my uptravel to about 3.75". since I have diy highline fenders, I have lots of room to play with.
now I have 29" long 12" travel shocks 5.5" max uptravel from ride height and 6.5" down travel, every bit of the articulation is useable although it can unseat the coils slightly... I have more plans for that...
here's some pics, what do ya think?
questions?
my original mock ups... some may remember seeing them posted several months ago..
this is one of my new ones..
I chopped off the top 2" of the shock towers.
ride height.
and properly set bumptops matched to the shock uptravel from ride height... notice it's 5.5"... better than half way into the bumpstop to allow for compression. the rubber stops nearly completely compress to nothing.
full droop.
rear...
and some forklift flex....
mudb8 is offline
post #99 of 339 Old 04-20-2009, 02:18 AM
rroadkilll
Did this on Saturday!!! More pics to follow...
post #100 of 339 Old 04-20-2009, 08:31 AM
nriver
2011 JK Wrangler
Looks interesting. I was thinking of a similar approach. Just have not made the cuts yet.
Why do I post here?
nriver is offline
post #101 of 339 Old 04-20-2009, 09:33 AM Thread Starter
mudb8
mudb8's Avatar
thanks lol,
I've seen several different versions, my original intention was a bolt on tower, it was getting dark and I gotta drive the thing to work now.. so I welded em.
so now when I get my long track bar done I started and remove the nth degree bar and brace I gotta extend the tower another two inches, remove the remainig bumptop which is there for the nth degree frame brace, add some 14" travel shocks and.... I'll have about 7" of uptravel if everything fits in there
mudb8 is offline
post #102 of 339 Old 04-22-2009, 02:13 AM
RUBtjICON
Man, I so badly want some T&T Tubes, but this is becoming very tempting...
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline
post #103 of 339 Old 04-22-2009, 09:21 AM Thread Starter
mudb8
mudb8's Avatar
lol, I hear ya, I held out for two years then bent one of my fenders pretty bad, still didn't have the money for what I wanted, so I just did it!
mudb8 is offline
post #104 of 339 Old 04-22-2009, 09:23 AM Thread Starter
mudb8
mudb8's Avatar
haven't seen thos pic's yet...
mudb8 is offline
post #105 of 339 Old 04-22-2009, 03:15 PM
carsonvogt
You said you're doing the tummy tuck yourself? When do you plan on starting that? I'd love to do it myself, so I'm always looking for a little inspiration.
Originally Posted by MikeBK
No, we are definitely crazy, but this is where we come to remind ourselves we are not alone. Brothers in Jeep insanity.
Survivalist Club Member #26
carsonvogt is offline
4" lift and 37's....coming up! Tomb Raider JK Wrangler Technical Forum 29 09-23-2010 04:43 PM
Unlimited Sahara overall height after 4" lift and 37's ravenite SC JK Wrangler Technical Forum 4 09-03-2009 09:04 PM
37's with a 3" lift. *temporary* BiGEN JK Wrangler Technical Forum 18 02-21-2009 10:15 AM
Any one running 37's with RC 6" lift RubiExpressTJ TJ Wrangler Technical Forum 18 02-01-2009 12:16 PM
37's on an Unlimited with a 4" Lift anyone? PSYCH0 JK Wrangler Technical Forum 8 06-09-2008 12:09 PM
