KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - Page 14 - JeepForum.com
post #196 of 339 Old 09-12-2011, 04:50 AM
Tylerzap
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #197 of 339 Old 12-08-2011, 12:15 PM
geiman
Looks awesome, might have to do this soon since it doesn't really cost anything! One question: it looks like you just cut the hood and leave it, is that right? I wasn't sure if you cut and then bent the edge or just left it.
geiman is offline
post #198 of 339 Old 01-26-2014, 01:21 AM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #199 of 339 Old 01-26-2014, 03:21 AM
SKIN
2006 XK Commander
What are you doing to your tires? Sipe'ing them?
SKIN is offline
post #200 of 339 Old 01-26-2014, 03:30 AM
alienator
I think is about better grip
alienator is offline
post #201 of 339 Old 01-26-2014, 06:27 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Rear 3 link?
Mail crawling.
MisfitSeven is offline
post #202 of 339 Old 01-26-2014, 10:11 AM
biffgnar
biffgnar's Avatar
Note the extra grooves in the pictures. Taking out a lot more rubber than just cutting for siping.
biffgnar is offline
post #203 of 339 Old 01-26-2014, 10:17 AM
rchase559
Grooving.
One reason to do it is to get a more desirable tread pattern. Another is to add some life into a worn out set by cutting the tread deeper.
Obviously the later has some ramifications such as decreasing the puncture resistance of the tire. Most people I know who groove for more tread depth do so on tires that are only seeing the trail.
rchase559 is offline
post #204 of 339 Old 01-26-2014, 11:23 AM Thread Starter
mudb8
mudb8's Avatar
Originally Posted by MisfitSeven View Post
Rear 3 link?
Front and rear.
9" separation @ the rear axle, front is still stock @ the axle, i just grew tired of the nose dive while braking and tossed in the upper to get rid of it.
mudb8 is offline
post #205 of 339 Old 01-26-2014, 11:27 AM Thread Starter
mudb8
mudb8's Avatar
The 37" claws are take offs from a dodge with a bad alignment. After cutting them the jeep is actually driveable.
Todd says, "hey! Now we have geo-claws"... Lol
Made a huge differnce in traction a.d driveabilty.
mudb8 is offline
post #206 of 339 Old 01-26-2014, 04:16 PM
MisfitSeven
MAiL Crawler.
They do look like the Yokohama Geolander mud terrains.
Mail crawling.
post #207 of 339 Old 01-31-2014, 08:35 PM Thread Starter
mudb8
mudb8's Avatar
Cant wait to get started on this...
mudb8 is offline
post #208 of 339 Old 02-12-2014, 01:36 PM
Matt Graham
Matt Graham's Avatar
x2?
Instagram:
Twitter:
Youtube:
My Build Thread:
F-250 7.3 Tow Rig Build Thread:
Matt Graham is offline
post #209 of 339 Old 02-12-2014, 01:39 PM
geiman
Originally Posted by Matt Graham View Post
x2?
Once you cut, you can trim the hood with this:
http://www.rokmen.com/all-products-1...edge-trim.html
geiman is offline
post #210 of 339 Old 02-12-2014, 02:45 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by mudb8 View Post
Front and rear.
what length arms are you running front and rear, uppers and lowers? what front UCA mounts are you running on the frame side? looks like you cut off the frame side LCA mounts and just moved them?
and ORIs
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
4" lift and 37's....coming up! Tomb Raider JK Wrangler Technical Forum 29 09-23-2010 04:43 PM
Unlimited Sahara overall height after 4" lift and 37's ravenite SC JK Wrangler Technical Forum 4 09-03-2009 09:04 PM
37's with a 3" lift. *temporary* BiGEN JK Wrangler Technical Forum 18 02-21-2009 10:15 AM
Any one running 37's with RC 6" lift RubiExpressTJ TJ Wrangler Technical Forum 18 02-01-2009 12:16 PM
37's on an Unlimited with a 4" Lift anyone? PSYCH0 JK Wrangler Technical Forum 8 06-09-2008 12:09 PM
