Knocking noise when I begin to brake - JeepForum.com
post #1 of 7 Old 02-02-2011, 10:11 AM Thread Starter
DylanAndre
I have an 04 Tj with a 4 inch rough country suspension and a 3 inch body lift. I already know the body lift needs to come off and that rough country is by far not top of the line but when I start to slow down there is a clicking/knocking noise... Any ideas guys? Thanks..
objcts in mirror are stuck...
DylanAndre is offline
post #2 of 7 Old 02-02-2011, 10:12 AM
tjsean0308
Is it repetitive or does it just knock once?
tjsean0308 is offline
post #3 of 7 Old 02-02-2011, 10:24 AM Thread Starter
DylanAndre
Repetitive
post #4 of 7 Old 02-02-2011, 04:03 PM
JeepMonky
I had something like this that would only happen when slowing down and I pushed in the clutch. Turned out to be my front driveshaft. So maybe check the u-joints in the front and back shaft Mine was a repetitive knock/clunk that was speed related.
JeepMonky is offline
post #5 of 7 Old 02-02-2011, 04:14 PM
05TurboS2K
Yea, need more info here man.
Speed related, RPM related, happen in neutral or not, same in every gear, 4hi, hardness of braking = louder sound, etc.
That'll help tons.
05TurboS2K is offline
post #6 of 7 Old 02-23-2011, 11:32 AM Thread Starter
DylanAndre
Only happens when slowing down while breaking... I have an automatic and it is a repetitive knocking clicking sound... Doesn't seems to
Sound different if I brake harder maybe a tad bit
post #7 of 7 Old 02-23-2011, 11:57 AM
TJRUSSELL
Dumb question but are your calipers tight...I drove a customers car and thats what the noise sounded like when one of the calipers were loose
My 2.4 turbo TJ-6 stretch build
http://www.jeepforum.com/forum/f22/my-lil-2-4-tj-build-1092494
TJRUSSELL is offline
Knocking noise salazarp TJ Wrangler Technical Forum 2 03-13-2007 01:51 PM
knocking noise Jaxbrian TJ Wrangler Technical Forum 1 01-13-2006 05:11 AM
<Sigh> Let the breaking begin...(2004 Wrangler is making weird noise) acelesson TJ Wrangler Technical Forum 7 01-31-2005 10:03 AM
knocking noise black pete YJ Wrangler Technical Forum 4 07-08-2003 08:45 AM
knocking noise DanG YJ Wrangler Technical Forum 3 07-05-2003 02:32 PM
