Knockin Comin from Front of motor - JeepForum.com
post #1 of 14 Old 04-12-2008, 05:40 PM Thread Starter
MercuryTec
When i started my 4.0 L my ears were not pleased. i heard a very bad knockin sound . Cleared up mostly after 20 sec but now i can here it tick for about 15 secs then goes away for little while or some times come and goes agian . I Believe it may be come from Vavles or posibly from somethin belt driven. Any help would be nice
MercuryTec is offline
post #2 of 14 Old 04-12-2008, 05:43 PM
tangofox007
Could be the harmonic balancer.
tangofox007 is offline
post #3 of 14 Old 04-12-2008, 05:43 PM Thread Starter
MercuryTec
How would it be clicking though ?
post #4 of 14 Old 04-12-2008, 05:44 PM Thread Starter
MercuryTec
Also sounds like it may drop about 50 rpm or so
post #5 of 14 Old 04-12-2008, 07:08 PM Thread Starter
MercuryTec
Bump any 1
post #6 of 14 Old 04-12-2008, 09:06 PM
snstj
tic sound with a drop in rpm could be a bad plug wire,look at the wires at night you might be able to see the spark jumping to ground. the knock on start up may be more serious, i would have a tech you trust look at it.
snstj is offline
post #7 of 14 Old 04-12-2008, 09:09 PM Thread Starter
MercuryTec
Dont have plug wires i have The distrubter less ignition
post #8 of 14 Old 04-12-2008, 09:12 PM
snstj
my bad! is it coil on plug, they have boots and can leak.
snstj is offline
post #9 of 14 Old 04-12-2008, 09:21 PM
87warrior
87warrior's Avatar
When I owned a YJ, I was able to stretch the timming chain that would slap the timming chain cover. I replaced the gear set and chain. However this would not "go away" after warming up.
I would suggest isolating the problem. Grab a crowbar and place the pointed end at various places on the engine block/head with it running. Place your ear at the curved part of the crowbar listening for the particular noise you are hearding. When you isolate the noise it will be easier to diagnose and fix.
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #10 of 14 Old 04-12-2008, 09:51 PM Thread Starter
MercuryTec
Well i was just doing that but with a slide hammer with weitgh removed i swear coming from #1 cyl at valve cover vavle problem like i said it realy bad at a cold start up
post #11 of 14 Old 04-12-2008, 10:39 PM Thread Starter
MercuryTec
Alright its not spark arching 100% sure i do know wat spark arching sounds like , and i checked anyways its well dark out nothin arching to block . Broke out the trusty slide hammer agian . When i go to the cyl num 1 valve cover bolt i can here the tick clear as day it goes slight tick to a pretty loud 1 . I checked all the other cylinders , dont seem to be making the loud tick a slight 1 but not loud so im pretty sure its #1cyl .
post #12 of 14 Old 04-12-2008, 10:42 PM Thread Starter
MercuryTec
Think i should just take valve cover of or bring it back to the dealer for the 5th time in last month it is still under powertrain warranty.
post #13 of 14 Old 04-13-2008, 01:25 AM
ErnieG
ErnieG's Avatar
sounds like a dirty lifter to me.. take the valve cover off and run the engine for a few secs see if you can isolate the noise that way
98 tj nothing special im too poor :(
ErnieG is offline
post #14 of 14 Old 04-13-2008, 09:24 AM Thread Starter
MercuryTec
Think i should go ahead and do it even though under warranty i can see them sayin not covered anyways . Any 1 know if the vavle cover gasket going to hold up when i remove the valve cover ?
Ticking / knockin noise from front end, when turning in 4LO Shiftywheelin TJ Wrangler Technical Forum 2 12-14-2011 11:01 AM
Knockin/Kluncking Noise BossYJ YJ Wrangler Technical Forum 11 04-10-2009 01:36 PM
knockin sound nicksbar YJ Wrangler Technical Forum 1 04-26-2008 08:40 AM
i got it back!!! knockin sound tho wakeboarder 21 TJ Wrangler Technical Forum 2 12-07-2003 09:22 AM
engine knockin at my door venturousviking YJ Wrangler Technical Forum 3 11-20-2001 07:35 PM
