Kill switch installed, now starter won't turn over...help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Kill switch installed, now starter won't turn over...help
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 08-04-2010, 02:46 PM   #1
Fokkerflyer
Installed kill switch, tied into starter motor wire. Used 14 gauge wires (about 10 feet to toggle switch and 10 feet back, if that matters) and used a toggle switch rated 10A 277VAC/ 20A 125VAC. Crimped 12 gauge ring terminals on the wires.
All installed and starter barely turns over, kind of like when the battery is really low. Redid starter wire back the way it was before and car started fine.
Going crazy trying to figure out why this happened. Anyone have any thoughts??
Thx,
FF
Fokkerflyer is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 02:50 PM   #2
Robert J. yates
Irony can be a real b!tch sometimes.
Robert J. yates is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 02:54 PM   #3
bnine
Like dad always says. Start with the last thing you did.............................
bnine is offline   Reply With Quote Quick reply to this message
Unread 08-04-2010, 02:57 PM   #4
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You actually spliced the switch into the wire connected to the starter? If so, carefully splice that wire back together and protect the splice so it doesn't give any problems. Instead, the kill switch should have been placed into the starter relay's primary side so the starter relay (located inside the Power Distribution Center) cannot energize when the kill switch is Off.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
kill , switch , issue , problem , tj , wrangler
