Kill switch installed, now starter won't turn over...help - JeepForum.com
post #1 of 4 Old 08-04-2010, 01:46 PM Thread Starter
Fokkerflyer
Installed kill switch, tied into starter motor wire. Used 14 gauge wires (about 10 feet to toggle switch and 10 feet back, if that matters) and used a toggle switch rated 10A 277VAC/ 20A 125VAC. Crimped 12 gauge ring terminals on the wires.
All installed and starter barely turns over, kind of like when the battery is really low. Redid starter wire back the way it was before and car started fine.
Going crazy trying to figure out why this happened. Anyone have any thoughts??
Thx,
FF
Fokkerflyer is offline
post #2 of 4 Old 08-04-2010, 01:50 PM
Robert J. yates
Irony can be a real b!tch sometimes.
Robert J. yates is offline
post #3 of 4 Old 08-04-2010, 01:54 PM
bnine
Like dad always says. Start with the last thing you did.............................
bnine is offline
post #4 of 4 Old 08-04-2010, 01:57 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You actually spliced the switch into the wire connected to the starter? If so, carefully splice that wire back together and protect the splice so it doesn't give any problems. Instead, the kill switch should have been placed into the starter relay's primary side so the starter relay (located inside the Power Distribution Center) cannot energize when the kill switch is Off.
Jerry Bransford is online now
kill , switch , issue , problem , tj , wrangler
Starter Kill Switch wmpiehl TJ Wrangler Technical Forum 12 04-01-2010 01:23 PM
Am I killing my starter and heat with my homemade kill switch? armartel TJ Wrangler Technical Forum 6 08-06-2008 11:16 PM
No Crank first try in cold weather, did I kill my starter? ElvisV04290 YJ Wrangler Technical Forum 10 01-20-2008 11:39 AM
Cheap Starter Kill Chris_Ryan TJ Wrangler Technical Forum 17 08-13-2006 09:40 PM
Starter Kill Question TellyDSP YJ Wrangler Technical Forum 20 08-28-2005 01:21 PM
