Quantcast Keys - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Keys
Jeep CJ, YJ, and TJ build your own bumper packages.Great deals on Rigid Lights. SR and E seriesJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 04-08-2008, 05:49 PM   #1
Tanker8
Keys
Does anyone know how to disconnect key sensor. I lost one of my keys and the dealer wants $50 for another key.
Tanker8 is offline   Reply With Quote
Old 04-08-2008, 06:35 PM   #2
Country Boy
Bovi-sapiens
Country Boy's Avatar
Zip tie your other key under the dash (probably should hide it pretty good!) and use a generic key without the sentry system. Its basically an RFID tag in the key that a transponder in the steering column reads when you turn the key. If a sentry key is within range, it will work, even if the key in the ignition is not a sentry key.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline   Reply With Quote
Glock Forum
