05-25-2011, 01:42 PM
#1
NEW YORK RANGERS
When I bought my 2005 Wrangler LJ they only gave me one key. The top is gray with a plymouth logo on it. When I told the Stealership how much is it to get a spare key copied they told me $180.00  and I was like $180.00 for a key, and they told me yeah, we have to do a chip program with it  ? Now I don't have an alarm system so what do they mean about a chip, could I just go to a Home Depot or Ace Hardware and have them copy me a key for under $5.00 dollars.
2005 LJ BDS 3" lift/JKS 1.25BL/MML/15x10/35 KM2's/RC Lca's
05-25-2011, 01:45 PM
#2
The key has a chip in it, and the Jeep will not start without that chip.
2000 Jeep Wrangler SE 2.5L Automatic
Black Jeep Society Member
2005 Ford F250 Lariat FX4 CrewCab PowerStroke 4x4
Trail Rated for Michigan Roads!
05-25-2011, 01:49 PM
#3
NEW YORK RANGERS
Really!
05-25-2011, 01:51 PM
#4
NEW YORK RANGERS
Originally Posted by Trendsetter75
Really!
For $180.00 dollars I can buy a steering stabilizer, 1.75 coil spacers, and Hi-lift jack and a full tank of gas. LOL!
#5
Yeah. It's a "transponder key" or something like that. I recently made more keys for my TJ, but thankfully do not have transponder keys, so was able to get cheap replacements.
05-25-2011, 01:54 PM
#6
Do a search for "Transponder Key", and you'll get plenty of hits.
http://www.jeepforum.com/forum/searc...rchid=11495310
Good luck!
05-25-2011, 02:27 PM
#7
Wooly Member
If you had 2 keys it would be alot cheaper to get one made.
The computer has to have two keys to program additional spares.
I have the original 2 keys locked in the safe just so they dont get lost.
Gray transponder keys run about 20-30 bucks on eBay.
2004 Black TJ Rubicon - 3" BDS lift, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - Dead stock and puny with 220k miles
05-25-2011, 02:40 PM
#8
Not that I recommend it necessarily, but a friend of mine was in the same situations. His solution was to remove shroud around the steering wheels and hide his original key inside it as near the ignition switch as possible. It's close enough for the sensor to read the signal and allows you to use non sensor equipped key blanks.
Of course it also eliminates the security of the system in the first place.
05-25-2011, 03:35 PM
#9
Over it
Just for peace of mind you can get a "clone" made at ace hardware and some wall marts for about 70$. It will not be second key but it will work.
Sent from Burger Kings' mens room.
LJ Owners Group member #431.
05-25-2011, 03:39 PM
#10
Or if your TJ is cool like mine, it drives without a key in it. I was driving one day, and it was a little bumpy and the key fell out and it didn't turn off the engine at all. Makes me think there might not be anything to this sentry system. I have yet to try and start it with a non-chipped key though.
05-25-2011, 03:53 PM
#11
Farm Wheeler
...The top is gray with a plymouth logo on it. When I told the Stealership how much is it to get a spare key copied they told me $180.00...
They want $180 because it's Plymouth key. Plymouth keys that work in Jeeps are very hard to get.
Keep in mind that free advice can frequently be worth less than you pay for it.
05-25-2011, 04:06 PM
#12
Living dead mod
don't think they had the sentry system in 99's.
anyway, the check is only done in the first few seconds after start up.
#13
The PO only gave me one transponder key when I bought my Jeep. I bought a couple of blanks on eBay for $15 for the pair. I had to go to the dealership for something else and they ended up cutting and programming both keys for me for about $40.
As someone mentioned above, you can also go to an Ace Hardware and have them "clone" your key for you. It will be a lot cheaper than the dealership. I don't know if the blanks I bought off eBay were capable of being made into clones or not.
There's a difference between the dealership "programming" your keys and the hardware store cloning them. Your Jeep is capable of having 5 different key codes attached to it. In my case now, I have a total of three different codes. If I take one of me keys to the hardware store and have them clone 5 copies of it, I'll have a total of 8 keys but still only 3 codes. That's why I said I didn't know if the blanks I bought off eBay were capable of being turned into clones.
Don't lose the key you've got!
05-25-2011, 04:11 PM
#14
Sent from Burger Kings' mens room.[/QUOTE]
05-25-2011, 04:19 PM
#15
They sure did. I tried to get my key copied at a hardware store and was told I couldn't because of the chip. Aside from that, the sentry key thing flashes on the dash when i turn it on.
