Keep your automatic transmission alive, review/installation of Derale's tranny cooler - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Keep your automatic transmission alive, review/installation of Derale's tranny cooler
Time To Save On Yukon Lockers!Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-03-2013, 11:12 AM   #241
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by JBTJ View Post
Because it does not matter.
Which way the ATF flows through the aux cooler inside the radiator doesn't matter, that is true. The difference between which is the inlet & which is the outlet on the bottom of the radiator does matter to the plumbing from the transmission though. The ATF flows one direction through the radiator cooler with 2002 and older TJs and the opposite direction with 2003 and newer TJs. That is due to the transmission's hard coolant lines, 32RH vs. 42RLE, and how they are bent & positioned for their connections to the cooler inside the radiator.
Getting Savvy...
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 06-03-2013, 11:15 AM   #242
JBTJ
Originally Posted by Jerry Bransford View Post
Which way the ATF flows through the aux cooler inside the radiator doesn't matter, that is true. The difference between which is the inlet & which is the outlet on the bottom of the radiator does matter to the plumbing from the transmission though. The ATF flows one direction through the radiator cooler with 2002 and older TJs and the opposite direction with 2003 and newer TJs. That is due to the transmission's hard coolant lines, 32RH vs. 42RLE, and how they are bent & positioned for connection to the cooler inside the radiator.
Correct, that's why I left him a PM where I could call him and possibly explain better.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 12:02 PM   #243
chmo
Once on my previous TJ I had a B&M transmission cooler in stacked plate design. I cannot recall the model number anymore ...
The instructions clearly warned from swapping in and outlet. Flow direction was predetermined.
Reason: it was a cooler built specifically as transmission oil cooler with built in cold oil bypass which only works correctly in one direction!
I can understand that coolers with in and out markings can cause questions...
[SIZE="1"]"The more I know, the more I realize how much I don't know"[/SIZE]
[URL="http://www.jeepforum.com/forum/f22/ls1-dd-softcore-sleeper-juggy-1397539/"][COLOR="Red"][B]my LS1 swap build thread[/B][/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f9/prothane-progressive-coil-spring-inserts-write-up-1150862/"][COLOR="red"]THE cheap progressive bump stop solution[/COLOR][/URL]
chmo is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 09:15 PM   #244
Crunchy
Anybody happen to know the flow rate of the tranny oil going to the radiator?
2005 Jeep Wrangler Rubicon
1999 Toyota Solara SEV6 5spd
2009 Toyota Highlander Sport
Crunchy is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 10:32 PM   #245
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
About 3 quarts in 200ft at 60 mph (32RH)...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 06-26-2013, 09:22 AM   #246
explorerlyon
explorerlyon's Avatar
How often does your cooler fan come on?
My fan is on most of the time. Even when the outside air temperate is 50, after driving for a bit the cooler fan kicks on. Seems like the fan is on way too often. My engine temperature holds at 210/220.
05 Rubicon Unlimited, Automatic
explorerlyon is offline   Reply With Quote Quick reply to this message
Unread 06-26-2013, 09:28 AM   #247
Jerry Bransford
Administrator
My Derale's fan is off more than it is on, even on really warm days.
Getting Savvy...
Unread 06-26-2013, 09:47 AM   #248
explorerlyon
So I wonder if my radiator is not cooling the tranny fluid as much as it should? The radiator was plugged with mud a while ago. I pressure washed all the mud out of the radiator fins. Other thoughts of what may cause the radiator to not cool the tranny fluid?
Unread 06-26-2013, 02:25 PM   #249
pwmac
Buy or borrow an infrared temperature gauge and see what the temp is. Measure the temp in and out on your cooler and in and out at the rad. I suspect your have a bad temp switch.
PW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is online now   Reply With Quote Quick reply to this message
Unread 06-29-2013, 09:30 AM   #250
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Do you have the cooler lines going through the radiator the correct way? If they're wrong the radiator isn't pre-cooling the fluid before it gets to the Derale, which could cause it to run more.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2013, 11:25 AM   #251
popeyesides
Mine is on most of the time also once it warms up, Seems like I have it hooked up right,,, Out of driver side radiator to cooler with temp switch, out of cooler to tranny!!!! sound right?
I even removed that return line behind cat completely. Now i come out of cooler and go straight into tranny.
popeyesides is offline   Reply With Quote Quick reply to this message
Unread 06-29-2013, 12:24 PM   #252
Jerry Bransford
Administrator
Yep you got it right, that is the correct side with 2003 and newer TJs.
Getting Savvy...
Unread 07-10-2013, 08:03 PM   #253
WhiteMtnJeep
It Should Have Been MEG!!
WhiteMtnJeep's Avatar
Installed mine yesterday. The bolts that hold the cooler to the bracket were a PITA and I wish the hose that connects to the hard line was about 3" longer. If it was I could have tied it off better over the DS. It have about 2' of hose flying through the air but I'm confident they are safe. The kit was also short 4 of the 1" foam squares and I had to make some. Other than that I'm satisfied with it.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
WhiteMtnJeep is offline   Reply With Quote Quick reply to this message
Unread 07-10-2013, 11:05 PM   #254
churchofjt
Another nod for a pretty darn good product. Mine's been on for a month or so and only rarely kicks on, even in 90+ weather. Still not used to it though, so it scares the crap out of me every time!
churchofjt is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 01:37 PM   #255
WhiteMtnJeep
I have a question about line routing up front.
I ran the cooler lines along the frame to the point where the factory lines all turn up. From there I have them tied together and they "fly through the air" over the DS/pumpkin to the radiator. The length of the lines doesn't offer much room for creativity. I'm pretty confident that they are out of harm's way but wish I could do something to make it easier to tie them down. Anyone have pics of their setup or suggestions?
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
