Keep your automatic transmission alive, review/installation of Derale's tranny cooler - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Keep your automatic transmission alive, review/installation of Derale's tranny cooler
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-22-2012, 03:21 PM   #151
threeb
Originally Posted by Mboelts
Has anyone run one of these through the cold winters here in the Northern states? Just wondering how this extra cooler might affect the warm up of the trans in freezing temps?
If you run it back through the radiator it will warm it if need be.
LJ Owners Group member #431.
threeb is offline   Reply With Quote Quick reply to this message
Unread 08-22-2012, 03:36 PM   #152
rusty762
rusty762's Avatar
Anyone running one of these with the Savyy UA?
Rusty
“If I had eight hours to chop down a tree, I’d spend six sharpening my axe.”- Abraham Lincoln
My Build
My Videos
My Work
Have you hugged a Firefighter today?
rusty762 is offline   Reply With Quote Quick reply to this message
Unread 08-22-2012, 05:22 PM   #153
RubiconRazorbac
RubiconRazorbac's Avatar
Not yet, but give me a couple of weeks...
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 08-22-2012, 10:41 PM   #154
Bedwell
1984 CJ8
Originally Posted by explorerlyon View Post
Yes, this will work with a bell-up skid. However, the cooler will be more exposed.
Ok, not a problem, however do you know if you can set it up for a manual switch?
Bedwell is offline   Reply With Quote Quick reply to this message
Unread 08-22-2012, 10:51 PM   #155
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes you can...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 08-23-2012, 07:42 AM   #156
Budke
Partially cover it up with a piece of cardboard when it gets real cold.
As for the coolers, no need to spend big bucks on a nig name brand one. I bought a used WJ trans cooler for $20 for my YJ and the difference in the trans temp on long journeys or when wheeling was like night and day. I mounted it in front of the radiator and it worked wonders.
Sent using the force
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline   Reply With Quote Quick reply to this message
Unread 08-23-2012, 08:02 AM   #157
SideshowBob024
Originally Posted by SideshowBob024 View Post
I wish this cooler was tucked up a little more. That spot on my jeep has taken some shots already.
Yeah, my concern is that belly up there isn't a place it won't eventually get smooshed or puntured by a stick or rock. I figured that area would be kinda safe then the first time out I managed to tear my pretty new driveshaft up right near the damn transfer case yolk.
Junkyard?
Did you route it before the radiator or after?
Hoses work from WJ?
SideshowBob024 is offline   Reply With Quote Quick reply to this message
Unread 08-23-2012, 08:05 AM   #158
geiman
Ditto; find the size cooler and fan you want, grab a thermostat and some wiring/hoses and install it. The Derale unit is certainly very nice and it takes the headache out of finding the parts individually, but I just can't see spending that much on a cooler when one can be made for much less money.
geiman is offline   Reply With Quote Quick reply to this message
Unread 08-23-2012, 09:34 AM   #159
Garza
Vendor
Garza's Avatar
It's all about fighting for real estate for some of us. I already have a big cooler in front of the radiator for steering. So for us LJ guys.....I really like where mine is.
'05 LSJ
'14 JKUR
www.4lowparts.com
Tactical Recovery Equipment
Garza is offline   Reply With Quote Quick reply to this message
Unread 08-23-2012, 09:40 AM   #160
geiman
I plan on putting my fan driven one in a similar spot under the tub.
Unread 08-23-2012, 10:32 PM   #161
mrblaine
Wizard of Brakes
mrblaine's Avatar
That one even clears triangulated uppers which go all the way up until they hit the bottom of the tub.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 08-23-2012, 11:12 PM   #162
SideshowBob024
Ooh that is a good spot, that shelf is bigger on the LJ than the TJ though, isn't it.
Unread 08-24-2012, 07:39 AM   #163
geiman
I'll have to keep that in mind when I finally get around to putting mine in; fortunately (or maybe unfortunately?) I don't have to worry about that quite yet.
Unread 08-24-2012, 07:48 AM   #164
SideshowBob024
I meant to slide under and see if there is any space there on the TJ this morning.
In a more northern climate, is it all that advantageous to have it under body versus in front of the radiator?
The disadvantages I see with up front is the lack of temp control/fan and the potential to increase underhood/coolant temps.
Unread 08-24-2012, 07:53 AM   #165
geiman
Personally I have a smaller manifold-type one in front of the radiator, and the fan driven one going underneath is more of a "just in case". I'm still researching parts in my spare time, but I'm thinking of getting a fluid control thermostat or two and bypassing the coolers as necessary so that they're only being used when actually needed.
