Keep your automatic transmission alive, review/installation of Derale's tranny cooler - Page 5 - JeepForum.com
 1Likes
post #61 of 523 Old 09-04-2011, 12:41 PM
Robert J. yates
Originally Posted by Knuckelhead
Why not have your expert post up on here with his input to help with the discussion? (Not dissing you)
Input is always welcome...
LOL..... Joe very well could be racing this weekend... he runs a top fuel dragster and has built transmissions for quite a few top teams in many different motorsports besides drag racing. He knows what he is talking about and doesn't need your approval.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #62 of 523 Old 09-04-2011, 12:49 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I didn't ask for his approval, I asked for his input.
Again Bobbie, you troll...
Knuckelhead is offline
post #63 of 523 Old 09-04-2011, 01:20 PM
larubie
Great write up! I am a little worried with that setup here in Louisiana where there is mostly mud on our trails. Huss the worst thing would be clogging the unit up. I have the new PSC trans and power steering cooler kit ordered which seems to be very nice. I will take pics once installed. I am doing the flexlite rad, fan, and thermostat setup along with the high flow water pump all at the same time.
Wherever I may roam...
larubie is offline
post #64 of 523 Old 09-04-2011, 01:43 PM
Robert J. yates
Originally Posted by Chucklehead
Again Bobby, you troll...
Yah.... that really hurt my feelings LoL.
Face it..... you just don't like it when someone has a different perspective which makes your's appear wrong. Seriously.... ATF is hot exiting the torque converter.... that's it's job so other than stuffing your dash with a bunch of fancy gauge nonsense you aren't accomplishing a thing for your transmission. Pan temp is the most important data point. The rest is for folks with to much OCD.
post #65 of 523 Old 09-04-2011, 01:51 PM
Knuckelhead
AFSOC Retired
You did give me a laugh for the day, and for that I thank you!
This is my OCD filter...
And yes, it's obvious that you're a troll...
post #66 of 523 Old 09-04-2011, 07:47 PM
JBTJ
Why there? What is the difference between there and the output line? You already know it's going to be cooler.
JBTJ is offline
post #67 of 523 Old 09-04-2011, 10:26 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Enough of the discussion on where to put the temp sensor, you're wrecking the intent of the thread guys. Please, it's an on-going thing between you and it doesn't need to continue in this Derale cooler thread! Grump.
I found some scrap 1/4" steel in my garage today, turned it into a quick guard for the bottom of the tranny cooler. Not quite a true skidplate but it will help protect the cooler against all but the most determined sharp rock. There's about 3/4" between it and the cooler so it won't restrict air flow through the cooler in the least. Most of us won't need anything like this and my air tank in that same location in my previous tank never took a hit but you can never be too careful when there are rocks around.
Getting
Jerry Bransford is online now
post #68 of 523 Old 09-04-2011, 10:32 PM
sduncan
sduncan's Avatar
Looks good Jerry. You'd have to put a little effort into finding a rock to damage it.
Thanks for the write up.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #69 of 523 Old 09-05-2011, 01:03 AM
Robert J. yates
So do you have the fan switched in the cab for water crossings Jerry? Seems to me you probably have more chance of drowning the fan than smacking the cooler with a rock. I've had 3 different coolers in that spot and have never had any of them on a rock.... water is a whole 'nother story tho. I've had water up to the top of the rear flares on the 'Con as well as up in Monache.
post #70 of 523 Old 09-05-2011, 01:06 AM
Robert J. yates
That is probably the 1 billionth time that pic has been posted LOL. Thanx!
post #71 of 523 Old 09-05-2011, 01:12 AM
Knuckelhead
AFSOC Retired
Your welcome...
post #72 of 523 Old 09-05-2011, 01:44 AM
chmo
Just an Observation:
recently I have been to the dealership because my 2->1 manual shifting (in some situations) seemed to be not working properly.
I have a B&M gauge and sender in the hot line.
The technician connected his mobile scan tool (DRBIII? it looks like a rubber armored multimeter with lots of buttons) to the OBDII port while I was driving around on road ... My B&M was showing 160*F ... HIS SCAN TOOL was saying 176*F !!!???
(But other than that he could not find anything strange ... I still have the 2-1 manual downshift issues especially if the B&M is showing around 200*F doing some soft sand driving)
so some questions arise:
1. the Jeep hand scanner gets his readings from where? (form the built in sender or calculated? Is the factory sender really in the coolest spot of the tranny?)
2. Why is my B&M in the HOT line showing less? inaccurate?!
(actually I doubt that, since I have a aux tranny cooler in front of the rad and these 160*F readings seem to be common in low load situations as stated by so many posts on JF)
3. Is it possible the factory sender is wrong/defective?
Something is wrong with the temp readings ... and my strange shifting behaviour could be explained if the pcm thinks the tranny is too hot and switching to another shifting table
In all these discussions I never found a hint about the reliability and accuracy of all the different sender and gauges ... (and at the end the factory temp sender/calculations is all what counts for the shifting tables )
"The more I know, the more I realize how much I don't know"
chmo is offline
post #73 of 523 Old 09-05-2011, 02:04 AM
Sgt.Fuzz
Subbed for reference. Lot of good info here (minus the bickering).
My build:
Sgt.Fuzz is offline
post #74 of 523 Old 09-05-2011, 04:45 AM
chmo
UPDATE (slightly off topic :
hehehe ... just an hour ago I pulled the trigger for a radical solution to my 42RLE woes and OPDA nightmares (including significant additional grunt)
got a COMPLETE low mileage (< 50k) and clean 2001 Holden/Chevrolet Caprice with built in LS1/4L60E ... for USD 3000,-
starting to collect parts for the swap now
until then I have some time to drive the Caprice a bit and check/verify that everything is ok
I will save my still in the box Derale 13960 30000 GVW cooler for the monster
chmo is offline
post #75 of 523 Old 09-05-2011, 05:53 PM
Yucca-man
So could you say the folks in this thread have done their best to "Derale" it?
Yucca-man is offline
k6rtm , pwmac
Transmission cooler installation question herath JK Wrangler Technical Forum 12 04-18-2011 08:21 AM
Automatic trans cooler Robbypfd YJ Wrangler Technical Forum 5 11-02-2009 07:53 PM
Automatic Transmission Oil Cooler Roger Frazer JK Wrangler Technical Forum 15 03-04-2008 07:09 AM
It's Alive!!! The tranny works!!! lah2420 YJ Wrangler Technical Forum 8 06-24-2006 08:09 PM
