Keep your automatic transmission alive, review/installation of Derale's tranny cooler - Page 2 - JeepForum.com
 6Likes
post #16 of 577 Old 09-02-2011, 12:12 PM
commodore_dude
commodore_dude's Avatar
Originally Posted by counselor View Post
One note: it doesn't seem they make a specific kit for the LJ, and although the TJ kit would work, the cooler won't be nearly as well protected since the LCA mount will be 10" further away.
Just a thought from a guy who owns an LJ and is always wondering how long the 42RLE is going to survive.
Yeah, I had originally responded to this writeup elsewhere, but all day I've been pondering this issue. Also just thinking about the length of the provided lines, etc.
2006 Rubicon Unlimited
1998 Buick LeSabre Custom
commodore_dude is offline
post #17 of 577 Old 09-02-2011, 12:29 PM
counselor
Well, for me, in south Louisiana, rocks aren't a problem, but that cooler would be caked with about 40 lbs. of mud the first time I took it out, so for my application, in front of the grill is the only way to go.
Question for those who know more about transmissions than me---will idling in park for an extended time frame (six hours) overheat the transmission? I think the torque converter is sitting there just basically slipping, but it's not in gear and there's no load. Just curious as I don't have a temp gauge.
And to answer the invariable question, because I sleep in my Jeep on trips with the A/C running.
counselor is offline
post #18 of 577 Old 09-02-2011, 12:37 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I was reading the FSM and it appears the engine computer calculated the transmission temp to be 260 degrees or hotter when my engine was overheating so badly last month. My transmission went into a limp-home mode where it was barely shifting and after reading what the FSM says, that pretty well confirms it was really hot... actually hotter than I suspected it was.
Based on how the FSM describes how the transmission shifts at various temps, mine had reached 260 degrees last month. What confirmed the transmission was getting too hot was that it went into a limp-home mode several times and was barely shifting when that happened. It started shifting ok again after it cooled off.
The '04 FSM says the transmission goes into an "Super Overheat Schedule" when the computer estimates the transmission to be 260 degrees or hotter which is calculated based on "torque converter slip speed, gear, engine temperature, and vehicle speed". So based on what the FSM is saying and how my transmission was shifting at its worst, my 42RLE got to over 260 degrees when the Jeep was overheating.
Per the '04 FSM...
Hot: Oil temperature at start up above 27C (80F)
> Goes to a Overheat schedule above 115C (240F)
oil temperature
> Normal operation (upshifts, kickdowns, and
coastdowns)
> Full EMCC, No PEMCC except to engage
FEMCC, except at closed throttle at speeds above
113-133 Km/h (70 - 83 MPH)
Overheat: Oil temperature above 115C (240F) or
engine coolant temperature above 118C (244F)
> Goes to a Hot below 110C (230F) oil temperature
or a Super Overheat above 115C (240F) oil
temperature
> Delayed 2-3 upshift 40-51 Km/h (25-32 MPH)
> Delayed 3-4 upshift 66-77 Km/h (41-48 MPH)
> 3rd gear FEMCC from 48-77 Km/h (30-48 MPH)
> 3rd gear PEMCC from 43-50 Km/h (27-31 MPH)
Super Overheat: Oil temperature above 127C
(260F)
> Goes back to a Overheat below 115C (240F) oil
temperature
> All a Overheat shift schedules features apply
> 2nd gear PEMCC above 35 Km/h (22 MPH)
> Above 35 Km/h (22 MPH) the torque converter
will not unlock unless the throttle is closed (i.e. at
80 Km/h (50 MPH) a 4th FEMCC to 3rd FEMCC
shift will be made during a part throttle kickdown
or a 4th FEMCC to 2nd PEMCC shift will
be made at wide open throttle) or if a wide open
throttle 2nd PEMCC to 1 kickdown is made.
Gone on vacation until August 25.
Jerry Bransford is offline
post #19 of 577 Old 09-02-2011, 12:49 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Nope.
When the transmission is in park, the torque coverter isn't under load and the fluid pump is not running (32RH) and with the 42RLE the pump does run when in park...
Knuckelhead is offline
post #20 of 577 Old 09-02-2011, 01:02 PM
SideshowBob024
Cool write up!
SideshowBob024 is offline
post #21 of 577 Old 09-02-2011, 01:39 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Nice work Jerry, added to the FAQ.
Wheelin98TJ is offline
post #22 of 577 Old 09-02-2011, 01:46 PM
geiman
Glad to see you've finally gotten around to doing this, I've been waiting on your writeup on the Derale unit before I took the plunge. Looks like a nice product, although I've already got an air tank in that location. Might have to re-route a few things but I'm sure it's worth it.
geiman is offline
post #23 of 577 Old 09-02-2011, 04:25 PM
F9K9
F9K9's Avatar
Originally Posted by F9K9 View Post
..........I am concerned with water and your set up. Any thoughts on the matter?
Thanks,
Reed
Bump for either Jerry or Blaine.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #24 of 577 Old 09-02-2011, 04:32 PM Thread Starter
Jerry Bransford
Administrator
Good question. Unless you wheel in salt water, no worries with it getting wet from water. You would not want to drive through deep water with the fan on but you could wire in a simple on off switch for that possibility... much like owners of jeeps with electric radiator fans do if they play in deep water.
Of course the fan will not normally be on so the need to turn the fan off when you're in deep water should be a rare event.
post #25 of 577 Old 09-02-2011, 04:33 PM
Xlr8n
1967 JK Wrangler
Jerry- I'll give you a big thanks for doing all the research on this as I was just getting ready to do the same.
The same tranny in my '05 threw an engine code (p0700) a few weeks back when I was just about to run out of my 70k powertrain warranty. No noticable symptoms, just the dashlight. Got in in last week (over 70k miles by then) and they diagnosed it. Ended up being the 'fuel saving' TC clutch overheated/let loose and sent shards of clutch material into the clutchpacks, pump, valve body, and radiator cooler. All the plates were scored. Complete rebuild from front to back including pump and TC totalling a bit over $2800 in dealer charged parts and labor. Luckily I only had to pay the $100 deductable.
Going to add a cooler to preserve the new trans this time around.
Xlr8n is offline
post #26 of 577 Old 09-02-2011, 06:02 PM
joe108
why didn't I find this 3 years ago before I installed mine in the front jerry, does the fan push the air away from the tub or suck it onto the bottom of the tub, does it matter? hot floor? just curious. great write up.
joe108 is offline
post #27 of 577 Old 09-02-2011, 06:05 PM Thread Starter
Jerry Bransford
Administrator
The fan pulls air up through the cooler from the bottom where it's cooler
post #28 of 577 Old 09-02-2011, 06:14 PM
gremlinsteve
i installed this kind of cooler/fan mod about 1 year ago. wired it into a toggle switch in fact. my 42rle has never seen more than 175-180 temps on the hottest of days in the longest of idle/slow moving times.
these temps are with outside air temps close to what you guys are seeing in your area btw. if i get air temps in the 80-90 range she sits at 140 or so and is happy
gremlinsteve is offline
post #29 of 577 Old 09-02-2011, 06:17 PM
Jeffro06
Jeffro06's Avatar
Price?
Jeffro06 is offline
post #30 of 577 Old 09-02-2011, 06:20 PM Thread Starter
Jerry Bransford
Administrator
Originally Posted by Jeffro06 View Post
Price?
$309 at places like www.Amazon.com and www.summitracing.com. It lists for $339.
Transmission cooler installation question herath JK Wrangler Technical Forum 12 04-18-2011 07:21 AM
Automatic trans cooler Robbypfd YJ Wrangler Technical Forum 5 11-02-2009 06:53 PM
Automatic Transmission Oil Cooler Roger Frazer JK Wrangler Technical Forum 15 03-04-2008 06:09 AM
It's Alive!!! The tranny works!!! lah2420 YJ Wrangler Technical Forum 8 06-24-2006 07:09 PM
