Keep your automatic transmission alive, review/installation of Derale's tranny cooler - Page 17 - JeepForum.com
 5Likes
post #241 of 562 Old 06-03-2013, 10:12 AM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by JBTJ View Post
Because it does not matter.
Which way the ATF flows through the aux cooler inside the radiator doesn't matter, that is true. The difference between which is the inlet & which is the outlet on the bottom of the radiator does matter to the plumbing from the transmission though. The ATF flows one direction through the radiator cooler with 2002 and older TJs and the opposite direction with 2003 and newer TJs. That is due to the transmission's hard coolant lines, 32RH vs. 42RLE, and how they are bent & positioned for their connections to the cooler inside the radiator.
Jerry Bransford is offline
post #242 of 562 Old 06-03-2013, 10:15 AM
JBTJ
Originally Posted by Jerry Bransford View Post
Which way the ATF flows through the aux cooler inside the radiator doesn't matter, that is true. The difference between which is the inlet & which is the outlet on the bottom of the radiator does matter to the plumbing from the transmission though. The ATF flows one direction through the radiator cooler with 2002 and older TJs and the opposite direction with 2003 and newer TJs. That is due to the transmission's hard coolant lines, 32RH vs. 42RLE, and how they are bent & positioned for connection to the cooler inside the radiator.
Correct, that's why I left him a PM where I could call him and possibly explain better.
JBTJ is offline
post #243 of 562 Old 06-03-2013, 11:02 AM
chmo
Once on my previous TJ I had a B&M transmission cooler in stacked plate design. I cannot recall the model number anymore ...
The instructions clearly warned from swapping in and outlet. Flow direction was predetermined.
Reason: it was a cooler built specifically as transmission oil cooler with built in cold oil bypass which only works correctly in one direction!
I can understand that coolers with in and out markings can cause questions...
"The more I know, the more I realize how much I don't know"
chmo is offline
post #244 of 562 Old 06-25-2013, 08:15 PM
Crunchy
Anybody happen to know the flow rate of the tranny oil going to the radiator?
2005 Jeep Wrangler Rubicon
1999 Toyota Solara SEV6 5spd
2009 Toyota Highlander Sport
Crunchy is offline
post #245 of 562 Old 06-25-2013, 09:32 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
About 3 quarts in 200ft at 60 mph (32RH)...
Knuckelhead is offline
post #246 of 562 Old 06-26-2013, 08:22 AM
explorerlyon
explorerlyon's Avatar
How often does your cooler fan come on?
My fan is on most of the time. Even when the outside air temperate is 50, after driving for a bit the cooler fan kicks on. Seems like the fan is on way too often. My engine temperature holds at 210/220.
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #247 of 562 Old 06-26-2013, 08:28 AM Thread Starter
Jerry Bransford
Administrator
My Derale's fan is off more than it is on, even on really warm days.
post #248 of 562 Old 06-26-2013, 08:47 AM
explorerlyon
So I wonder if my radiator is not cooling the tranny fluid as much as it should? The radiator was plugged with mud a while ago. I pressure washed all the mud out of the radiator fins. Other thoughts of what may cause the radiator to not cool the tranny fluid?
post #249 of 562 Old 06-26-2013, 01:25 PM
pwmac
Buy or borrow an infrared temperature gauge and see what the temp is. Measure the temp in and out on your cooler and in and out at the rad. I suspect your have a bad temp switch.
PW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #250 of 562 Old 06-29-2013, 08:30 AM
Jeffro06
Jeffro06's Avatar
Do you have the cooler lines going through the radiator the correct way? If they're wrong the radiator isn't pre-cooling the fluid before it gets to the Derale, which could cause it to run more.
Jeffro06 is offline
post #251 of 562 Old 06-29-2013, 10:25 AM
popeyesides
popeyesides's Avatar
Mine is on most of the time also once it warms up, Seems like I have it hooked up right,,, Out of driver side radiator to cooler with temp switch, out of cooler to tranny!!!! sound right?
I even removed that return line behind cat completely. Now i come out of cooler and go straight into tranny.
popeyesides is offline
post #252 of 562 Old 06-29-2013, 11:24 AM Thread Starter
Jerry Bransford
Administrator
Yep you got it right, that is the correct side with 2003 and newer TJs.
post #253 of 562 Old 07-10-2013, 07:03 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Installed mine yesterday. The bolts that hold the cooler to the bracket were a PITA and I wish the hose that connects to the hard line was about 3" longer. If it was I could have tied it off better over the DS. It have about 2' of hose flying through the air but I'm confident they are safe. The kit was also short 4 of the 1" foam squares and I had to make some. Other than that I'm satisfied with it.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #254 of 562 Old 07-10-2013, 10:05 PM
churchofjt
Another nod for a pretty darn good product. Mine's been on for a month or so and only rarely kicks on, even in 90+ weather. Still not used to it though, so it scares the crap out of me every time!
churchofjt is offline
post #255 of 562 Old 07-13-2013, 12:37 PM
GilaMtnJeep
I have a question about line routing up front.
I ran the cooler lines along the frame to the point where the factory lines all turn up. From there I have them tied together and they "fly through the air" over the DS/pumpkin to the radiator. The length of the lines doesn't offer much room for creativity. I'm pretty confident that they are out of harm's way but wish I could do something to make it easier to tie them down. Anyone have pics of their setup or suggestions?
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
Transmission cooler installation question herath JK Wrangler Technical Forum 12 04-18-2011 07:21 AM
Automatic trans cooler Robbypfd YJ Wrangler Technical Forum 5 11-02-2009 06:53 PM
Automatic Transmission Oil Cooler Roger Frazer JK Wrangler Technical Forum 15 03-04-2008 06:09 AM
It's Alive!!! The tranny works!!! lah2420 YJ Wrangler Technical Forum 8 06-24-2006 07:09 PM
