Keep your automatic transmission alive, review/installation of Derale's tranny cooler - Page 11 - JeepForum.com
 6Likes
post #151 of 577 Old 08-22-2012, 02:21 PM
threeb
Originally Posted by Mboelts
Has anyone run one of these through the cold winters here in the Northern states? Just wondering how this extra cooler might affect the warm up of the trans in freezing temps?
If you run it back through the radiator it will warm it if need be.
LJ Owners Group member #431.
threeb is offline
post #152 of 577 Old 08-22-2012, 02:36 PM
rusty762
Anyone running one of these with the Savyy UA?
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
Have you hugged a Firefighter today?
rusty762 is offline
post #153 of 577 Old 08-22-2012, 04:22 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Not yet, but give me a couple of weeks...
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #154 of 577 Old 08-22-2012, 09:41 PM
Bedwell
1984 CJ8
Originally Posted by explorerlyon View Post
Yes, this will work with a bell-up skid. However, the cooler will be more exposed.
Ok, not a problem, however do you know if you can set it up for a manual switch?
Bedwell is offline
post #155 of 577 Old 08-22-2012, 09:51 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes you can...
Knuckelhead is offline
post #156 of 577 Old 08-23-2012, 06:42 AM
Budke
Partially cover it up with a piece of cardboard when it gets real cold.
As for the coolers, no need to spend big bucks on a nig name brand one. I bought a used WJ trans cooler for $20 for my YJ and the difference in the trans temp on long journeys or when wheeling was like night and day. I mounted it in front of the radiator and it worked wonders.
Sent using the force
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #157 of 577 Old 08-23-2012, 07:02 AM
SideshowBob024
Originally Posted by SideshowBob024 View Post
I wish this cooler was tucked up a little more. That spot on my jeep has taken some shots already.
Yeah, my concern is that belly up there isn't a place it won't eventually get smooshed or puntured by a stick or rock. I figured that area would be kinda safe then the first time out I managed to tear my pretty new driveshaft up right near the damn transfer case yolk.
Junkyard?
Did you route it before the radiator or after?
Hoses work from WJ?
SideshowBob024 is offline
post #158 of 577 Old 08-23-2012, 07:05 AM
geiman
Ditto; find the size cooler and fan you want, grab a thermostat and some wiring/hoses and install it. The Derale unit is certainly very nice and it takes the headache out of finding the parts individually, but I just can't see spending that much on a cooler when one can be made for much less money.
geiman is offline
post #159 of 577 Old 08-23-2012, 08:34 AM
Garza
It's all about fighting for real estate for some of us. I already have a big cooler in front of the radiator for steering. So for us LJ guys.....I really like where mine is.
Garza is offline
post #160 of 577 Old 08-23-2012, 08:40 AM
geiman
I plan on putting my fan driven one in a similar spot under the tub.
geiman is offline
post #161 of 577 Old 08-23-2012, 09:32 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That one even clears triangulated uppers which go all the way up until they hit the bottom of the tub.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #162 of 577 Old 08-23-2012, 10:12 PM
SideshowBob024
Ooh that is a good spot, that shelf is bigger on the LJ than the TJ though, isn't it.
post #163 of 577 Old 08-24-2012, 06:39 AM
geiman
I'll have to keep that in mind when I finally get around to putting mine in; fortunately (or maybe unfortunately?) I don't have to worry about that quite yet.
geiman is offline
post #164 of 577 Old 08-24-2012, 06:48 AM
SideshowBob024
I meant to slide under and see if there is any space there on the TJ this morning.
In a more northern climate, is it all that advantageous to have it under body versus in front of the radiator?
The disadvantages I see with up front is the lack of temp control/fan and the potential to increase underhood/coolant temps.
post #165 of 577 Old 08-24-2012, 06:53 AM
geiman
Personally I have a smaller manifold-type one in front of the radiator, and the fan driven one going underneath is more of a "just in case". I'm still researching parts in my spare time, but I'm thinking of getting a fluid control thermostat or two and bypassing the coolers as necessary so that they're only being used when actually needed.
geiman is offline
Transmission cooler installation question herath JK Wrangler Technical Forum 12 04-18-2011 07:21 AM
Automatic trans cooler Robbypfd YJ Wrangler Technical Forum 5 11-02-2009 06:53 PM
Automatic Transmission Oil Cooler Roger Frazer JK Wrangler Technical Forum 15 03-04-2008 06:09 AM
It's Alive!!! The tranny works!!! lah2420 YJ Wrangler Technical Forum 8 06-24-2006 07:09 PM
