Quantcast KC light wiring question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > KC light wiring question
Old 08-26-2004, 12:17 AM   #1
Jeep14636
I've searched (and found some hits) on this subject but still have a question: My wiring is complete but the stock fog light switch I purchased for the bezel blank stays lit. I ran the switched lead to my parking lamp fuse. To test it, I simply wedged it into the fuse slot with the fuse in it.
Any suggestions? How should I permanently wire this, assuming I can get it to ONLY come on when the lights are turned on.
Thanks
Yeah.....and I'm a Chinese jet pilot
02 Sahara with Dual Tops
Warn x8000i on Tomken winch mount
Sony Head Unit with integrated iPOD, 10 disc changer, Pioneer amp
Cobra CB with Firestik antenna
Raingler nets
RE 4.5 SF with 3.5" springs
AA SYE with a Woody
33 x 12.5 BFG AT's on Cragar Soft 8's
Jeeperman rear bumper and tire carrier
Jeep14636 is offline   Reply With Quote
Old 08-26-2004, 12:53 AM   #2
Hal
if you have the ground wire correct on the toggle switch, try switching the other 2 power wires around.
[b]'02 TJ Sport[/b]
Hal is offline   Reply With Quote
Old 08-26-2004, 08:30 AM   #3
Jeepxj96
I dont know if this is what you need, But try this KC Wiring
Bob
1996 Land Rover Discovery with a bunch of stuff on super swampers
Jeepxj96 is offline   Reply With Quote
Old 08-26-2004, 10:50 AM   #4
hardwarp
can you install kc side windshield lights with a snorkel??? just wondering as I want to order both at once...and do you know if the kc lights are waterproof...I am assuming they are?
hardwarp is offline   Reply With Quote
Old 08-26-2004, 02:10 PM   #5
hardwarp
just wonderin if anyone knows the answer?
Old 08-26-2004, 03:21 PM   #6
Jeepxj96
I have seen kc's on with a snorkle... I plan on getting a snorkle soon.
Bob
Old 08-26-2004, 08:56 PM   #7
ninjajeep
Mine are pretty well sealed, but being that high up(windshield mounted) you shouldn't have to worry about them getting too wet...
'01 TJ 60th Anniv. Ed.
"6 cylinders of gut wrenching torque"
ninjajeep is offline   Reply With Quote
Glock Forum
