Quantcast KC Light hookup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > KC Light hookup
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 08-14-2009, 10:36 AM   #1
savageride
KC Light hookup
I recently installed a pair of KC lights on my front bumper. There was pre-existing wire hook up to plug into. There is also a fuse for fog light hookup. but my jeep doesnt have the foglight pullout switch on the column. so i guess what im trying to ask is.... is there anything to hook into behind the dash to install a switch or something?
savageride is offline   Reply With Quote
Old 08-14-2009, 10:38 AM   #2
MC_NickP
i didnt. just ground your swtich and relay, power your swtich and relay and you are good to go
they give you so much wire, i stuffed it behind the center console
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
http://www.jeepforum.com/forum/f22/mc_nickps-black-tj-build-1036334/#post9499802
MC_NickP is offline   Reply With Quote
Old 08-14-2009, 10:40 AM   #3
03JeeperX
03JeeperX's Avatar
1991 XJ Cherokee
Below your radio there should be 4 spots for the stock switches....I believe there are wires behind there to hook a switch to mine has them there.
R.I.P....03 TJ 4.0L NV3550 NP231 3 inch lift and 33x12.5x15 MTZ on Crager Black D-Style Rims Rock Lights---Wrecked---
1991 XJ 4.0L NP231 3" Lift 31's....Mods in progress....
03JeeperX is offline   Reply With Quote
Old 08-14-2009, 10:43 AM   #4
Sobie
Bolt-on Maniac
Sobie's Avatar
what kc lights are they, how many watts are each bulb?
Sobie is offline   Reply With Quote
Old 08-14-2009, 10:56 AM   #5
tjchuck
yea i just installed 100w slimlite fog's and just drilled a hole large enough in blank slot in the dash where the Mopar switches would have went if my TJ came with Factory fog lights and put the KC switch in there. Wiring these things is really really easy.
tjchuck is offline   Reply With Quote
Old 08-14-2009, 10:59 AM   #6
Sobie
Bolt-on Maniac
Sobie's Avatar
and you used the factory wiring??
Old 08-14-2009, 11:06 AM   #7
savageride
yea there was factory wiring in the front for fog lights.
Old 08-14-2009, 11:15 AM   #8
Sobie
Bolt-on Maniac
Sobie's Avatar
i wouldnt run anything more than 55 watt lights on those wires. thats what the factory fogs were. it might be ok, but id rather play it safe instead of trying to find an electrical gremlin one day.
Old 08-14-2009, 11:37 AM   #9
tjchuck
"i wouldnt run anything more than 55 watt lights on those wires. thats what the factory fogs were. it might be ok, but id rather play it safe instead of trying to find an electrical gremlin one day."- agreed
Old 08-14-2009, 11:43 AM   #10
PILL
That wire looks too weak for 55w as is, and anything more is just asking to burn your Jeep down.
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline   Reply With Quote
Glock Forum
