kc headlight - JeepForum.com
post #1 of 11 Old 10-02-2010, 09:14 PM Thread Starter
southernss
kc headlight
just looking for some feedback. is anyone running the the new kc headlights yet.
Feature Products Headlight Jeep Tj KC HiLiTES: Auxiliary Lighting, HID Off Road Lights, Fog Lights, Driving Lights, Light Bars, Wiring Accessories
southernss is offline
post #2 of 11 Old 02-05-2011, 07:32 AM
cvisinho
bumping this for info as well
cvisinho is offline
post #3 of 11 Old 02-05-2011, 07:54 AM
TimV
I put mine in about a month ago. Seem to be a much nicer pattern than the stock lights I had. However, I am not using the bulbs that came with them. I have a set of 90w low, 100w high beam bulbs in mine. I already had the bulbs laying around, so I figured I would put them in. The quality is very nice for my initial impression. Very solid, and actually much lighter than the sealed beams. LCoG!
It's not an addiction. It's a way of life.
TimV is offline
post #4 of 11 Old 02-05-2011, 12:28 PM
BlueFlame
BlueFlame's Avatar
You can buy the same lights on eBay for $25....
example
http://cgi.ebay.com/ebaymotors/65-78...Q5fAccessories
BlueFlame is offline
post #5 of 11 Old 02-05-2011, 01:13 PM
03GoldTJ
example
But these don't have the cool glow-in-the dark KC logo,however!
03GoldTJ is offline
post #6 of 11 Old 02-05-2011, 01:23 PM
2006_Sport
The only issue I would have with these is the poly carbonate housings (lexan). Plastic usually yellows out over time which reduces light output. Only time will tell though.
I ended up with Delta Quadbar hyperwhite xenons, 110 bucks and they have glass housings and look better IMO. I've had em for a year and am very happy.
2006_Sport is offline
post #7 of 11 Old 02-05-2011, 01:24 PM
monkeee2002
example
Those aren't the same lights. I've tried those you linked before - they're just shiney junk. After a few months I noticed rust on the reflector. That little blue light looks super cheap when you turn it on, and the blue finish on the little bulb fades after a while, leaving you with a nasty color that is neither blue nor green, but rather an entirely new color of light bluish-brown.
I put the KC's on my TJ last fall; I like the way they look, but for $100, I was expecting them to be brighter.
...I'll have to look into upgrading the bulbs as Tim mentioned...
The skinny pedal on the right is my friend. the gas gauge is not.
monkeee2002 is offline
post #8 of 11 Old 02-05-2011, 01:24 PM
Best4x4
Those Ebay wonders = CRAP and the quality is HORRIBLE and as the saying goes you get what you pay for!
I found these at a local 18wheeler shop and the quality is excellent! They've got glass lens, a metal reflector, and an excellent waterproof seal at the back and they cost $37.00 each.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #9 of 11 Old 02-05-2011, 01:37 PM
jdub36
I have had the Kc's for awhile now. They are ok, much better than stock but i am sure if you do some searching you could find some housings and pick a better bulb. I just ordered them because i have two other sets of KC's and i really like them.
jdub36 is offline
post #10 of 11 Old 02-05-2011, 01:54 PM
Maverickxeo
I have a set of the ebay lights... better than stock lighting; although they could be better. I replaced the lights with H4 silverstars and they are much better; although they are still not the best. I couldnt see spending much more on them. The high beams though are WAY too bright up close; but thats fine, the lows are good enough; and the highs could work well when night wheeling.
Maverickxeo is offline
post #11 of 11 Old 02-05-2011, 03:41 PM
redo4x
I got a set of them for christmas. Much better than stock. I can actually tell the difference between low and high beams now. Just running the bulbs that come with them for now. I will probably get some silverstars for them later.
Don't have a closeup picture of them yet.
33x12.50 Mtz's, Ome lift, 3/4 front spacers, Jks 1.25 bl and mml, Warn 9000, Rockcrawler front and rear bumpers, Warn fog/driving lights, Rubicon flares
redo4x is offline
only one headlight UNCLEBRO TJ Wrangler Technical Forum 13 07-13-2013 09:58 AM
Headlight dim gryph YJ Wrangler Technical Forum 4 05-08-2010 11:59 AM
Headlight Help!!! Wildcat83 TJ Wrangler Technical Forum 2 03-27-2010 12:49 PM
TJ Headlight? GilNewJeeper TJ Wrangler Technical Forum 5 03-15-2010 08:09 PM
Headlight out on 99 tj nopa TJ Wrangler Technical Forum 7 03-10-2009 06:28 PM
