Kargo Master/Thule Roof Rack = Loud - JeepForum.com
post #1 of 12 Old 04-08-2008, 04:12 PM Thread Starter
ohfourtj
I know this is a long shot but does anyone have this setup on their roof? It sounds like a wind tunnel whenever I'm going over 50 mph. I'm wondering if it's possible to buy a wind fairing for this sort of thing. Are there any TJ specific fairings out there?
This is what the setup looks like:
http://s283.photobucket.com/albums/kk281/ohfourtj/
ohfourtj is offline
post #2 of 12 Old 04-08-2008, 04:38 PM
jcssurf
It's the front tube of the kargo master that makes it so loud. I found a thread through the search a few weeks ago where people talked about fairing ideas. Basically you'll want something from the windshield frame to that front tube to make it quieter.
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline
post #3 of 12 Old 04-08-2008, 04:46 PM
distantdog
I have the exact same set-up. Kargo Master with thule load bars. Yep it is loud. Look at it though, its not exactly aero-dynamic.
Like the previous post said, the only way to reduce the noise would be to reduce the wind resistance.
That being said, really, how quiet is the ride without the rack at 50mph+? It ain't a Cadillac.
distantdog is offline
post #4 of 12 Old 04-08-2008, 04:56 PM
maddiver
I have the same set up with yakima bars on it. Tried a fairing without any luck. Then I found a little $17 fix that Yakima makes called a windjammer. This thing is a little plastic wing that goes right on the bar. Just one reduced my wind noise significantly so I put one on each bar (one front, one back) and now it's much better.
I found the one above at Eastern Mountain sports for $17.00: http://www.ems.com/catalog/product_d...cid=GoogleBase
I've also seen on a thread somewhere else where somebody was suggesting filling the tubes of the KargoMaster with that expanding foam insulation - somehow that is supposed to cut down on the resonance. I have a brandy-new kargocage out in the garage that isn't even put together yet - I'm gonna try the foam insulation in it - will let you know how it works out.
maddiver is offline
post #5 of 12 Old 04-08-2008, 07:34 PM
olyjeep
I may be off base here but I could have sworn I heard of people wrapping a bungee cord in a screw fashion around the front bar from one side to the other and that somehow helped divert the wind and cut down on the noise.
maybe worth a shot?
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #6 of 12 Old 04-24-2009, 11:30 PM
Mickey650b
I'm using a Yakima rack, Kargo Master rack with a modified Yakima Fairing.
My Kargo Master rack was very noisy too, so I made an air foil from a sheet of metal stripped from an old micro wave oven and riveted it on. It was a temporary solution until I could figure out something better. It did okay and did help cut down the noise a little. I finally bought a Yakima Fairing, cut it to fit my Kargo Master rack and made a few more modifications to it. It's done a great job and there's practically no additional noise coming from the rack compared to the noise I have driving my jeep without the rack installed.
I spent some time trying to figure this one out. It really has made a huge difference in my wind noise. Hope you find it useful or sparks some ideas.
Mickey650b is offline
post #7 of 12 Old 04-25-2009, 01:02 AM
Red Rubycon
Red Rubycon's Avatar
I used to have a THule bike rack on my Saab. THey made a spoiler like thing that went o the front to deflect the air, worked great, cheap too - $50
Red Rubycon is offline
post #8 of 12 Old 04-25-2009, 07:03 AM
red rubi
So long pal!
red rubi's Avatar
The location of the front bar makes a difference too. Move it forward above the windshield. I have heard a rope or bungee works as well.
red rubi is offline
post #9 of 12 Old 07-01-2011, 09:30 AM
JKEK
2014 JK Wrangler
I know this is an old thread but here's what worked for me
When I installed on my 2011 JKU with hard top I got what could be described as a harmonic vibration that came on at 40 MPH. It was definitely not wind noise. I purchased the wedge that Kargo master makes for their Truck racks and while waiting decided to give the leading edge a helix rap using 3/4 in nylon rope. Worked like a champ. in fact, I'm not sure it didn't make the overall roof noise go down a bit.
The wedge arrived a couple of days ago and I plan to install tonight or tomorrow. If it doesn't work as well as the rope it'll be coming off.
JKEK is offline
post #10 of 12 Old 08-06-2011, 12:32 PM
Kcbcdavis
Congo cage and Thule
2011 4dr, looking at a Congo rack but need Thule crossbars. Anyone have a clue on what mounts would work to rig up some Thule cross bars?
Kcbcdavis is offline
post #11 of 12 Old 08-07-2011, 04:32 PM
JKEK
2014 JK Wrangler
Thule 450 Crossroad
I have the KargoMaster rack but no cage. The 450 Crossroad has a rubber coated steel strap that tightens around the bar. Works great. I have a pick posted over at wrangler forum with my JKU loaded for the lake.
http://www.wranglerforum.com/gallery...mageuser=57809
JKEK is offline
post #12 of 12 Old 11-17-2012, 02:47 PM
DrBeeperMD
2009 JK Wrangler
Thule 450 Crossroads and Kargomaster JK 4 door
Just installed both Thule crossbars and new Kargomaster Congo cage. The cage takes a good 3 hours and you really do need someone to help. You will need a good socket wrench set and a set of Torx bits also. Go through forums and threads, all good advice prior to the install. My old Thule generic footpads did not expand to accommodate the large diameter Congo cage side rails, but Thule 450s work great, very strong and good fit
DrBeeperMD is offline
Anybody have homemade mounts for Kargo Master roof rack? linexrandy TJ Wrangler Technical Forum 1 03-30-2009 01:58 PM
What is the better roof rack, Garvin Exp. Rack or Kargo Master Drew99 TJ Wrangler Technical Forum 6 03-17-2009 04:33 PM
Kargo Master rack & Thule products DirtHerder TJ Wrangler Technical Forum 1 06-19-2007 09:14 PM
Kargo Master rack height Elbobo TJ Wrangler Technical Forum 4 10-01-2006 12:56 PM
kargo master rack nyjeeperman TJ Wrangler Technical Forum 13 08-15-2006 09:50 PM
