Quantcast K&N FIPK Maintenance - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > K&N FIPK Maintenance
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 12-31-2003, 04:10 PM   #1
coolguycarlos
HI I bought a KN FIPK for my TJ a long time ago, and I keep hearing about dirt gettin into the engine, how can I check that, I want to know if I have the same problem, plus does anybody know of any maintenence tips I should be taking!
[quote]Mommy please dont turn off the lights... Mirko will come and high kick me in the face[/quote]
[B][COLOR=Red]Red Jeep Club Member #76[/COLOR][/B]
[URL=http://www.jeepforum.com/forum/showthread.php?t=82882][B][COLOR=Green][SIZE=2]Green Jeep Club Number Giver Out Dude[/SIZE][/COLOR][/B][/URL]
01 TJ Sport Flame Red, 33" ProComp M/T, Alloy Look alike Baja Rims, 4" ProComp lift, 4.56 Gear Ratio, Banks Exhaust and Header system, K&N FIPK, Airaid Throttle Body Spacer, and lost of SS accesories :-)
[URL=http://www.console.iscentral.net][COLOR=LightBlue]Hack Ur PS2[/COLOR][/URL]
coolguycarlos is offline   Reply With Quote
Old 12-31-2003, 07:00 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
K&N makes a pre-filter called an Outerwears that provides additional filtration. On top of that, I placed an oiled Unifilter foam filter. That kees the additional dust out of my engine that the K&N by itself was letting in.
So far as maintenance of the K&N goes, just clean it with a good quality detergent from the inside out, rinsing from the inside of the filter towards the outside. I use Simple Green, 409, or Fanastic... all have worked well for me. Or you can use K&N's special cleaner, although it's pretty expensive.
Once it's clean and dry, you must use K&N's special oil to treat it so it can work as effectively as possible. Nothing else will work properly so if you don't buy K&N's cleaner, at least buy and use K&N's filter oil. In-between washings, K&N says it's ok to occasionally spray it with more oil (right over the trapped dirt) to keep its filtration level up as high as possible.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Glock Forum
