just a water pump question - JeepForum.com
post #1 of 5 Old 07-04-2013, 01:56 AM Thread Starter
romiin
I noticed my jeep leaking antifreeze when I shut it off. when its running it stops leaking. its dripping off the harmonic balancer. i took out the pump, but of course you wreck the gasket so I am not sure if it was a gasket problem. any one had this happen. the little seep hole on the top of the pump was'nt seeping any fluid, all the hoses look good thermostat isn't leaking. I'm kinda stumped.
2000 tj 4L
00 sahara
romiin is offline
post #2 of 5 Old 07-04-2013, 02:01 AM
Necko2529
Necko2529's Avatar
Did you reinstall the pump with a new gasket? Is it still leaking?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 5 Old 07-04-2013, 09:49 AM
marka2k
2006 WK
I had a similar issue with my 2000 WJ I6 the thermostat housing where the top radiator hose attaches was eaten away at the lip and coolant was seeping out from there, I ended up replacing the housing (Autozone $10) and hose since it was soft in the area where the coolant was leaking, since you already pulled the pump I would replace the gasket and reinstall and see as mentioned above, if its still doing it check the thermostat housing.
Hope this helps
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #4 of 5 Old 07-04-2013, 08:21 PM Thread Starter
romiin
necko, I think your onto something there. But as luck would have it, the pump had a life time warrenty. so I put a new pump in, doesnt leak anymore. I did think too it might of been the gasket. The original pump started leaking at about 60,000 miles. this after market one(made in china) had about 85,000 miles on it. so i thought it was time to change the pump. so much for original equipment being better
thanks for the input
00 sahara
romiin is offline
post #5 of 5 Old 07-04-2013, 08:42 PM
Necko2529
Necko2529's Avatar
As long as its not leaking all should be well. If leaking out the weep hole the pump is bad if between the block and pump i would suspect the gasket is bad...
Good luck.
