Just ordered a 2"BB 1.25"BL and 1"MML - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Just ordered a 2"BB 1.25"BL and 1"MML
SYE Kits from CCOR! 706-207-4140Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 10-09-2014, 04:08 PM   #1
Sesco4
So I ordered a 2" Budget Boost 1.25" Body lift and a 1" Motor Mount Lift. Is there anything else i will need to go along with all of this to make it work. Sorry if this is a dumb question but while I have my jeep apart I want to make sure its right.
Thanks
Sesco4 is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 04:11 PM   #2
biffgnar
biffgnar's Avatar
Shocks and rear bumpstop extensions with the BB?
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 10-09-2014, 04:13 PM   #3
Sesco4
Yes comes with it.
Unread 10-09-2014, 04:13 PM   #4
dtn8tr
dtn8tr's Avatar
An RMA number to send it back and then the IRO website...3" lift springs with shocks for $389.http://www.ironrockoffroad.com/Merch...egory_Code=PFT
1997 TJ, 4" ProComp, 33x12.5x15 Firestone Destination MT, JKS Quicker disconnects
sold-1988 YJ, 4.2L, 2.5" OME, .75" boomerangs, 33x12.5x15 Cooper Discoverers, Herc'd,Nuttered, TeamRush'd
2001 WJ stock DD, 4.0l, Select-Trac
Most good stories start out "Y'all ain't gonna believe this ****...."
dtn8tr is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 07:22 AM   #5
sharparte
How did this work out?
sharparte is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 08:28 AM   #6
Sesco4
don't know yet. suppose to pick jeep up next weekend. Will update after i get it back.
Unread 10-10-2014, 08:39 AM   #7
tyvanwie
Lol
[SIZE="4"][B][COLOR="Red"][URL="http://www.jeepforum.com/forum/f22/tys-tj-1475530/#post14926343"]MY BUILD THREAD[/URL][/COLOR][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f374/tyvanwies-log-transformation-1489190/"]MY FITNESS LOG/TRANSFORMATION[/URL][/B][/SIZE]
[SIZE="4"][B][URL="http://www.jeepforum.com/forum/f127/jk-tj-parts-1525039/"]JK AND TJ PARTS FOR SALE[/URL][/B][/SIZE]
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 09:28 AM   #8
dtn8tr
dtn8tr's Avatar
Thanks
I'm not being a wiseass or giving you grief...you stated that you wanted to make sure that you were doing it right and that 3" suspension lift can't be much more than what you are laying out now, and IRO warranties all of their stuff (IRO branded) for life. You buy IRO springs and they sag 5 years from now...they will replace them. If you plan on wheeling it the suspension is the way that you want to go. If you are just going to be mall crawling it then what you chose will work just fine because you are not needing the flex or articulation.
Unread 10-10-2014, 09:52 AM   #9
tyvanwie
What about the driveline angles from a 3" lift? Will he be dropping the transfer case to help that? You do realize stock jeeps go offroading too right? What makes you think a BB and BL setup won't work offroad?
Unread 10-10-2014, 10:37 AM   #10
Sesco4
If I had the extra money that would be great. I purchased the jeep about four months ago only to find out that the frame was bad. So besides the cost of the jeep now I'm replacing the frame and I also need tires. In a perfect world I would love to but a legitimate suspension lift under it but I don't live in said perfect world. Thanks to all for the input keep it coming.
Unread 10-10-2014, 11:09 AM   #11
joe_jeep
There is nothing else u absolutely need.
Install that stuff, and see how u like it.
Many jeeps have that exact setup.
anything else u might want u can install later.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 12:09 PM   #12
biffgnar
biffgnar's Avatar
Your original plan is fine. And if you wanted to do 3" lift there are much better options than Iron Rock.
