just lifted, get alignment now or after tires? - JeepForum.com
post #1 of 11 Old 09-22-2008, 01:51 PM Thread Starter
alecmcmahon
just put a 2.5" RC lift + 1.25" BL on my 99 TJ
i know i need an alignment, but im also going to be going from 31's to 33's in the near future.
if i get an alignment now, do i have to get another one after putting bigger tires on?
the cheapest i can find is 80 bucks for an alignment around me. i'd hate to have to pay twice.
alecmcmahon is offline
post #2 of 11 Old 09-22-2008, 01:54 PM
Xlr8n
1986 TJ Wrangler
Align it yourself now for free using the thousands of links and tutorials available on this forum and then double check it after your new tires. 15 minutes of time in the driveway and a couple wrenches, a tape measure, and maybe some vise grips or a plumbers wrench. It's that easy.
http://www.4x4xplor.com/alignment.html
Xlr8n is offline
post #3 of 11 Old 09-22-2008, 02:56 PM
HipCheck_1
After lifting your jeep you may now have excess toe in.
Having too much toe-in can make your Jeep wobble especially when hitting a bump while going around a curve.
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline
post #4 of 11 Old 09-22-2008, 03:07 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
do it now before you get your tires mounted. driving on the road out of alignment is bad news. you can do an alignment yourself or you can get it done at a reputable place. Big O i find has excellent tools for that application.
My builds:
and
or follow us on
spyder6 is offline
post #5 of 11 Old 09-22-2008, 04:13 PM Thread Starter
alecmcmahon
thanks, I'm getting a computerized alignment at a local shop right now
post #6 of 11 Old 09-22-2008, 04:36 PM
Xlr8n
1986 TJ Wrangler
Cha-ching! The only adjustment needed to the front end of a solid axle rig like your Jeep is toe in-out which is covered in the link I gave you. They'll simply do the 5 minute adjustment in the link and collect 80 bucks for it. Oh well.
Xlr8n is offline
post #7 of 11 Old 09-22-2008, 04:40 PM
BlackBellamy
BlackBellamy's Avatar
you should do your own alignment it's only one measurement
your local computerized alignment shop is staffed by a pimply seventeen year-old who's busy thinking about everything else other than precise alignment
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #8 of 11 Old 09-22-2008, 04:49 PM
Bigbob
Bigbob's Avatar
Did that lift kit come with adjustable control arms? If yes then a good alignment may have been a good idea to make sure all is square with the world. If the stock control arms are still on and the shop charged you $80.00 they screwed you and don't use them again. Without adjustable control arms the only thing they could have done was the toe-in adjustment and getting the steering wheel centered.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is online now
post #9 of 11 Old 09-22-2008, 04:52 PM
Bigbob
Bigbob's Avatar
Oh, BTW, to go from 31 to 33 no additional alingnment should be needed.
6 Speed, Hardtop
post #10 of 11 Old 09-22-2008, 05:06 PM Thread Starter
alecmcmahon
the guy actually spent 40-50 minutes working on it, i watched him. he said it was way off.
and it actually does feel alot better.
i dont mind paying a few bucks if it comes down to saftey.
here is the print out:
post #11 of 11 Old 09-22-2008, 05:09 PM Thread Starter
alecmcmahon
I live in the suburbs, where people will charge what they want, cause they will pay it.
this guy was actually the cheapest i found, i got some quotes @ 125-150 bucks,.. this guy charged me 75.
TJ alignment and overall lifted vehicle "inspection"...where??? 06BlackRubicon TJ Wrangler Technical Forum 1 05-16-2009 02:37 PM
Just lifted... When to get an alignment? sailmike83 YJ Wrangler Technical Forum 13 02-11-2009 05:29 PM
shackles, tires, and alignment Think YJ Wrangler Technical Forum 7 05-12-2006 12:45 PM
lifted tj alignment ???'s rajincajingt TJ Wrangler Technical Forum 3 10-18-2004 04:02 PM
tires and alignment scutt TJ Wrangler Technical Forum 2 03-18-2004 09:38 AM
