Just installed 5.5" RE long arm kit - JeepForum.com
post #1 of 7 Old 11-12-2005, 06:14 AM Thread Starter
countryboy4ya
Just a quick question....I just installed a RE 5.5" lift and I have noticed that the front sits lower then the rear. I do not have additional weight such as a winch or rear tire carrier yet. I will be installing a homemade tire carrier this weekend and it is pretty heavy, but I do not know if it will level out the suspension yet. My question is: is it common for my rear to sit higher? would the front regain some height once I dial in my axles?
2001 Red Jeep TJ Sport. ARB Snorkel, K&N filter, 62MM TB, Banks Exhaust System, Optima Red Top, 5.5" RE lift, Rock Sliders, Painless Cirkit Boss, 4 KC Titanium Daylighters, CB, Inclimeter, Herculiner, Neoprene seat covers, Dana 30 front, Dana 44 rear, 4.88 gears, Novak Conversion T-case Shifter linkage, Teraflex ES SYE kit, 37" Boggers, Currie Steering Conversion,
countryboy4ya is offline
post #2 of 7 Old 11-12-2005, 06:35 AM
eagleno49
throbbing member
eagleno49's Avatar
You will likely need a spacer up front to level it out. Wait until your axle angles are adjusted and your bumper is on before you add one.
running like a raped ape
eagleno49 is offline
post #3 of 7 Old 11-12-2005, 06:43 AM
camoTJ
camoTJ's Avatar
it will sit alittle higher... thats how my moms sits, I kind of like it like that. shes got a tire carrier and 35 on the back and a winch up front
1 tons 106" wb 40's....just like everybody elses
camoTJ is offline
post #4 of 7 Old 11-12-2005, 09:50 AM
Joel77
RE 5.5" springs are a little to high for 35" tires.
And adding a spacer on top of that is very high.
Might want to consider dropping to 4.5" springs.
Joel77 is offline
post #5 of 7 Old 11-12-2005, 10:01 AM
U.S.MarineLJ
U.S.MarineLJ's Avatar
The Jeep has a natural rake to it. The rear sits higher stock. This is so that when you load the rear down with gear/equipment the *** end doesn't sit lower.
Great site to read about and review Jeep related products.
Awesome site with writeups.
Another awesome site for writeups.
U.S.MarineLJ is offline
post #6 of 7 Old 11-12-2005, 10:13 AM
moitura
moitura's Avatar
After my 4.5 LA kit was installed, I thought it was lower in the front too, but then upon further investigation, I discovered it was an optical illusion created by the fender flares. The rear flares are bolted to the jeep in a *slightly* higher location than the fronts, giving it that sloped front look. Although there are cases where the front of a jeep really does sit lower than the back, most the time, IMO, I think its just an optical illusion.
moitura is offline
post #7 of 7 Old 11-12-2005, 06:51 PM
rkutzner
rkutzner's Avatar
YES YES YES, you are right on !!! Measure the frame between the front and rear tires before they bend upwards. Mine was 'level' though the flares make the Jeep look a little raked. Measure one that looks 'level' or higher in front and the frame WON'T be level. The other issue is to let the springs settle in for a few hundred miles and an offroad trip before adjusting with coil spacers. I actually had to add a half inch to my passenger side rear to get everything 'perfect' after a year. And yes, I DID swap coils left and right first, with no change....
2001 TJ Sport
Everything SELF INSTALLED.
The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more !
rkutzner is offline
4.5" RE long arm installed- now shifting probs. Help? VanBCguy TJ Wrangler Technical Forum 11 12-02-2009 06:10 PM
RE 4.5" Tri-Link Long Arm - INSTALLED! SuperWade2 TJ Wrangler Technical Forum 46 11-30-2009 07:14 AM
Installed Full Traction 4" long arm, pics Slc JK Wrangler Technical Forum 2 03-20-2008 07:40 AM
rock krawler 4" x factor long arm installed happycamper TJ Wrangler Technical Forum 8 10-26-2007 09:27 PM
My Jeep with 5.5" RE Long arm kit installed Jbirdman97TJ TJ Wrangler Technical Forum 27 08-13-2004 07:53 AM
