Just had my first death wobble "like" experience. Please conferm solution. - JeepForum.com
post #1 of 10 Old 08-27-2009, 09:41 AM Thread Starter
ACDJeeper
Took the Jeep to have the 42k service done. They rotated the tires during the service and I noticed that the front was a little "wobbly" on bumps. I shrugged it off as the tread/tire pressure since the service.
Went on a 750 Mile camping trip, still a little wobbly mostly at about 48 - 50 MPH. Then on the last few miles of the trip on the way home while in slower highway traffic the front went nuts! I could still hold the steering wheel but it was shuddering in my hands hard. I had read on these forums that the only way to stop this wobble was to slow down to a stop. I managed to pull over and it went away at about 10 MPH.
I am going to assume this is the bad tire balance problem and not true death wobble (stock Jeep with different rims and tires in profile). So from what I have read I need to go and have all 4 tires checked and perfectly balanced?
ACDJeeper is offline
post #2 of 10 Old 08-27-2009, 09:43 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
i just had deathwobble yesterday. it was fixed by a tire balance - my wheels are now mostly made of lead :
get them balanced and you should be good.
My builds:
and
or follow us on
spyder6 is offline
post #3 of 10 Old 08-27-2009, 09:45 AM
mdm
Farm Wheeler
Tire balancing is the first thing to look at.
Death wobble can and does happen to Jeeps with completely stock suspension, steering, wheels, and tires.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 10 Old 08-27-2009, 09:48 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Have the tires road force balanced.
Your problem is the tires or the wheels.
A road force balance will tell you if the wheels and tires are still balanced when they have a load on them.
Wheelin98TJ is offline
post #5 of 10 Old 08-27-2009, 09:57 AM Thread Starter
ACDJeeper
Is a tire place like Les Schwab good enough to do this work?
post #6 of 10 Old 08-27-2009, 09:59 AM
Wheelin98TJ
JEEP FREAK
If they have a tire machine that does road force balance, then yes.
You can search for local shops that have a road force balance machine at this link:
http://www.gsp9700.com/pub/search/findgsp9700.cfm
post #7 of 10 Old 08-27-2009, 10:41 AM Thread Starter
ACDJeeper
Thanks for that link!
Looks like they do, will let you guys know what happens.
post #8 of 10 Old 08-27-2009, 11:43 AM
otisdog
2008 WK
If that doesn't work check your trackbar for tightness or perhaps worn out mounting holes.
jim
08 Grand Cherokee Overland
otisdog is offline
post #9 of 10 Old 08-28-2009, 09:20 AM Thread Starter
ACDJeeper
I have to admit Les Schwab is a customer centric place! The did the road force balance and checking of the track-bar for free because the previous owner bought the tires at another Les Schwab (Receipts were in road kit in glove box).
The tech said the tires were in much better balance after he took all the previous weights off! He then of course re balanced them and said the track-bar was nice and tight. The Jeep drives better than ever. I tried to get the conditions to entice Wobble of Death and it just wouldn't do it. Awesome.
Thanks for the tips guys. Case Closed.
post #10 of 10 Old 08-28-2009, 09:24 AM
digitalcox
digitalcox's Avatar
Glad to hear it was only a tire balance issue. Unexpected death wobble is always a pleasant experience.
Justin
2004 Jeep Wrangler l 1946 Willys CJ2A l 1988 BMW 325 l 2009 Triumph Thruxton
digitalcox is offline
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
My adventure with "death wobble" disarm6565 YJ Wrangler Technical Forum 15 10-16-2008 11:33 PM
Is my front end trouble "death wobble" or... regular wobble? TheMightyGoat TJ Wrangler Technical Forum 6 07-13-2008 12:27 AM
another "bad vibration/death wobble" at 50mph thread...pls help boze_man TJ Wrangler Technical Forum 3 06-06-2008 02:01 PM
