Just curious... - JeepForum.com
post #1 of 10 Old 03-29-2008, 11:57 PM Thread Starter
djfuzzy
Just curious...
I recently had a check engine light come on, not sure of the reason for that yet, but I noticed that there was something tickling my foot while I was driving around. I took a peek under the dash and found that the tickling wire was the passenger airbag switch wire. I spliced it up real nice and secured it a little better and there is no more tickling of the foot.
But...as I was poking around under the dash, I noticed two connectors to which I could not see where they were supposed to be plugged in. I was wondering if these two connectors had anything to do with the check engine light. I am trying to avoid taking it somewhere to get the codes ran because in Hawaii, nowhere does it for free, and it generally costs about $100-150 to get it ran. Anyway, I have attached pictures of the particular connectors under the dash that I am talking about. If anyone can shed some light on this, that would be sweet.
Thanks, pictures are as follows.
Also, I tried feeling around to see if they should be plugged in somewhere and had no luck. And if it helps to identify the connectors, I have a 2000 TJ Sport I6 with an M5.
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #2 of 10 Old 03-30-2008, 12:07 AM
UTWeezul
Originally Posted by djfuzzy View Post
I have a 2000 TJ Sport 6.0 with an M5.
6.0 with an M5????
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #3 of 10 Old 03-30-2008, 12:31 AM Thread Starter
djfuzzy
Yeah dude...umm...I built it myself?
Haha, my bads. Anyway, 4.0L is more appropriate I suppose. I was trying to get y'all to believe I had a real badass Jeep.
USMC 2006-Present
djfuzzy is offline
post #4 of 10 Old 03-30-2008, 01:09 AM
randonlee25
I know for a fact that the first one has nothing to do with it, that plug is an accessory plug. (mine is hooked up to my alarm)
If you were afraid to open that little bag and look inside, don't even think about opening the hood. There's a whole bunch of complicated crap hidden under it.
randonlee25 is offline
post #5 of 10 Old 03-30-2008, 02:33 AM
Red_
2016 KL Cherokee
2nd plug is for illuminating the automatic gear selector
Red_ is offline
post #6 of 10 Old 03-30-2008, 07:46 AM
Pillswoj
If it is that expensive to get codes read, why not buy a reader for ~$100 then you can check yourself.
Pillswoj is offline
post #7 of 10 Old 03-30-2008, 01:19 PM
CCrew
or on/off the key three times and read it yourself for free.
R
CCrew is offline
post #8 of 10 Old 03-30-2008, 03:11 PM Thread Starter
djfuzzy
R
Because I didn't know I could do that. If I did, this thread probably wouldn't exist.
And thanks for identifying the plugs.
USMC 2006-Present
djfuzzy is offline
post #9 of 10 Old 03-30-2008, 03:22 PM
Pillswoj
Try the key trick but don't be surprised if it does not work, it doesn't on 99's and I think 2000's are the same way.
Pillswoj is offline
post #10 of 10 Old 03-30-2008, 03:56 PM Thread Starter
djfuzzy
Well...I went to try the key trick...and the CEL was off. So...I guess I fixed it by thinking about fixing it. I disco'ed the battery for about a minute after the light went off to make sure it didn't come on again, and it didn't.
USMC 2006-Present
djfuzzy is offline
Just curious will it last ToddS76 TJ Wrangler Technical Forum 4 05-31-2009 11:20 PM
Curious about this.... bryris YJ Wrangler Technical Forum 7 03-27-2009 01:29 PM
Curious about POR-15 USCGTWEET TJ Wrangler Technical Forum 7 09-08-2008 01:23 AM
Curious as to how much I should ask for my YJ leon23 YJ Wrangler Technical Forum 7 04-13-2007 10:30 AM
SE Curious SpitNine TJ Wrangler Technical Forum 10 08-17-2006 09:30 PM
