Quantcast Just a click, no engine turnover in cold weather - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Just a click, no engine turnover in cold weather
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 11-29-2007, 09:35 PM   #1
raskull
My jeep doesn't like to start in cold weather.
I have a heated garage so it starts fine in the morning, but when I go to leave work I get a clicking sound like the battery is trying to turn the starter over, but no go.
A little background on the issue before we get into this:
Same problem last winter.. I ended up taking the starter apart and noticed the solenoid was all gummed up with rust. New starter for about $70 and the problem was mainly fixed. Happened once with the new starter then never happened again.
This winter it got cold and the problem came back. I figured my weak battery might be the cause, winching and all that stuff can do no good to it. I bought a really nice Optima red top with 800CCA. Problem still exists..
It only does it when the weather is *cold*. -10 C (14F) it's fine.. but when it drops to -15 (5F) or -20 (-4F), it does it every time.
I've found two temporary solutions.. one is to start the jeep once in a while and plug in the block heater.. this prevents my block from ever dropping to that low of a temperature, and it will start ok.
The other remedy is to sit there and click it over and over for five minutes or so (can't be good for it I know), and it will eventually turn over and start.
Obviously it's not the battery.. I have LOTS of power, and I could sit there and click and try to crank it for 45 minutes and still have plenty of power to start it. The battery is a brand new 800CCA cranking battery. It's not likely that I've wrecked a starter in less than a year, but it's possible..
An other ideas?
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote
Old 11-29-2007, 09:51 PM   #2
safarimike
Is it a rebuilt starter? I have heard those things are Junk.
1999 Jeep Wrangler Sport
safarimike is offline   Reply With Quote
Old 11-29-2007, 10:55 PM   #3
hecubus
1997 XJ Cherokee
sounds like a bad connection somewhere...you can have voltage but too small a contact point and there's no way enought amps will flow to turn your engine; as you know when it gets cold metal shrinks and the amperage you need to start a car is substantial. I'd check/clean/coat with that electro goo/ both battery terminals and the starter connection/s and sacrafice a chiken
"eh, it's the bank's jeep anyway..."
hecubus is offline   Reply With Quote
Old 11-30-2007, 05:18 PM   #4
raskull
I have checked the connections to the starter before, but I will do so again tonight. I also put in my brother's starter relay and it did not help..
(O|||||||O)
l_l*-----*l_l
My build thread
Old 11-30-2007, 06:55 PM   #5
CrzyWhtBy
If you get a click it is usually the battery; however if your lights are not dim, probably not the case. Probaby a bad starter or bad connection somewhere.
"Early to finish...Late to start"
CrzyWhtBy is offline   Reply With Quote
Old 11-30-2007, 08:01 PM   #6
Waldn
What oil are you using?
I would suggest 5w-30 for the winter
97 TJ SE 2.5L Auto, 3" BDS, 255/85-16 BFG MT KM
04 KJ LTD Frankenlifted, Full Mopar Armor, front reciever hitch for winch, Rubicon Moabs and MTRs
Waldn is offline   Reply With Quote
Old 11-30-2007, 08:48 PM   #7
gdl
I know it's a long shot but maybe it's the battery cables and/or the locations to which they connect. I could imagine if the ground was marginal it could maybe cause something like this.
gdl is offline   Reply With Quote
Old 11-30-2007, 08:57 PM   #8
Waldn
ignore my last post, I was thinking it was turning over slow.
I agree with gdl, sounds like a bad connection or possibly a bad starter solenoid.
Old 11-30-2007, 08:57 PM   #9
BradG
Bad spot on the flywheel? We have a burban out at work that we used to have to turn over by hand with a wrench if the starter was on the bad spot on the flywheel. PITA. Though that wasn't a click... more of a painful nails-on-chalkboard sound of screeching metal.
2003 TJ X Silver | 31x10.50x15 BFG A/Ts | 10k front tow hooks, factory rear tow hook | 2" coil spacers | Cobra 19 with RatShack 102" stainless whip on an Arizona RockyRoad tire carrier mount | Kilby Steering Box Skid | AtoZ Fabrication Rock Sliders | Olympic Slider Rear Bumper w Receiver | Skid Row Engine/Oil/Tranny skid (still sitting in my living room)
BradG is offline   Reply With Quote
Old 11-30-2007, 08:57 PM   #10
shtev87
If you know the battery is good and using a block heater eliminates the problem i agree with waldn that running a thinner oil could help the problem
shtev87 is offline   Reply With Quote
Old 11-30-2007, 09:09 PM   #11
shtev87
yea i was also wrong about suggesting oil, thinner oil could help but id look at connections first also if u have a volt meter a couple simple voltage drop tests could give u the answer
Glock Forum
