just bought this winch will it work alright for my jeep - JeepForum.com
post #1 of 11 Old 06-18-2010, 10:46 AM Thread Starter
macho78
Just picked up a winch for a couple hundred and was wondering if 5000lb winch will work for what I want. I'm only using the jeep on light trails and nothing to extreme. I wanted it incase I go off the road in the winter I could possibly pull my self out with it.
Uncle Henry's
Looking at some of the previous post it looks like these can be gone through and rebuilt pretty easy as well. That good because it looks like this one is going to need to be cleaned up.
macho78 is offline
post #2 of 11 Old 06-18-2010, 10:48 AM Thread Starter
macho78
Also was a $200 a good deal for it? Probably should of done some research before buying it(lol).
macho78 is offline
post #3 of 11 Old 06-18-2010, 10:50 AM
superslayer
5,000 lbs isn't enough pull, IMO.
TJ's at the very least need an 8,000 lb winch.
superslayer is offline
post #4 of 11 Old 06-18-2010, 11:17 AM
xlch
If you use a snatch block it will double your pulling power.
Tanks do well at crossing ditches and running stuff over but other than that a Jeep will get you anywhere a tank will and more.
Now the tank might get beter gas milage but that is a different story.
xlch is offline
post #5 of 11 Old 06-18-2010, 11:20 AM
jeepinmichguy_
this, for $100 more you could have gotten a proper winch.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #6 of 11 Old 06-18-2010, 11:24 AM
theducksguts
If you spent 300 dollars you got robbed, if you spent 200 you overpaid.
The Warn M8000 winches are not that expensive.
Check out my
theducksguts is offline
post #7 of 11 Old 06-18-2010, 11:24 AM Thread Starter
macho78
woops, looks like I have a winch for the car trailer now(lol). Thanks for the help.
macho78 is offline
post #8 of 11 Old 06-18-2010, 11:35 AM
jdub36
If i was stuck and had my choice between a 5,000 pound winch and no winch at all i would def take the 5,000 pound winch. If that is all you have it is better than nothing, but i think 8,000 pounds would work alot better.
jw
jdub36 is offline
post #9 of 11 Old 06-18-2010, 11:48 AM
jeepinmichguy_
jw
that is just bad advice.
ΜΟΛΩΝ ΛΑΒΕ
post #10 of 11 Old 06-18-2010, 11:55 AM
Matt99362
Rule of thumb for a which is get a winch that is rated at twice the weight of your vehicle. Considering my TJ Sport started out at 4500lbs, I wouldn't go with anything lighter than an 8000 or 9000 lb winch. The reason for this is simple. If you are stuck, you are not just pulling the weight of the Jeep. You're pulling the Jeep THROUGH whatever you're stuck in. This can add serious weight.
A 5000lb winch would be great for a car trailer because for the most part you are moving rolling weight rather than stuck weight.
Matt99362 is offline
post #11 of 11 Old 06-18-2010, 11:59 AM
JDePietro
2010 JK Wrangler
You can increse the power by using snatch blocks. But anyway you cut it I don't think that it will last very long. Sorry.
Man's got to know his limits.
JDePietro is offline
winch
Jeep folk are alright!!!!! mrspradlin Wrangler General Discussion 26 01-08-2009 05:06 PM
alright.... I give up on my jeep please help bamato YJ Wrangler Technical Forum 21 05-20-2006 06:54 PM
Just bought this winch! Dozer. TJ Wrangler Technical Forum 41 02-28-2006 07:06 PM
I couldnt find redline mt-90 so i bought royal purple max-gear 75w-90, alright??? chaznad TJ Wrangler Technical Forum 2 08-27-2005 11:25 AM
Alright, I guess I need to start doing some work.. Alheim YJ Wrangler Technical Forum 2 06-13-2004 01:36 PM
