Just Bought Another Wrangler & Already Having Issues.. - JeepForum.com
post #1 of 73 Old 03-11-2010, 07:08 PM Thread Starter
97TJnSC
Well as you can tell by my name I use to have a 97 tj back in the day.. Last night I purchased another Jeep after thinkin bout my old one for 5 years. I picked up a 02 Sport 80k auto tranny. Once paying for the Jeep I started down the road and a hour down the road, I stopped to get gas and had the first of a set of problems.. Im gonna list them below..
First Problem: Oil light came on once I started the Jeep at idle along with the "check Gauges light" it was reading 0 psi until I gave it gas and started down the road then the psi's returned to around 40 and ran fine.. (today I changed the Oil Sending unit and after about 100) starts it seems to be fine)
Second Problem: Once every Five starts the starter wouldnt engage. No click nothing, I could turn the key 20 times with nothing, I finally put it in neutral and i fired right up. ( I changed the Neutral Safety switch and it seems fine again after 5 or so starts)
Third Problem: Once the Jeep is warmed up it almost sounds as if its a diesel. I cant tell where its coming from almost sounds as if the oil pump is making the noise.. Its faint when cold but once its warm you can hear it very good. Its not a rod, lifters or anything I cant trace it. I did a oil change last night including 10w30 GTX High Mileage oil, Napa Gold Filter, STP treatment, Engine Restore... The oil was absolutely filthy, so i added a bottle of engine flush before the change.. ( So what is the noise im hearing I have searched the site and cant find anything)
Also did a tranny flush today with new filter and gaskets.. Shifts good now I was worried due to the fluid being absolutely nasty..
I know its alot of reading but problem number three is killin me.. Please help
97TJnSC is offline
post #2 of 73 Old 03-11-2010, 07:47 PM
EvilM0nkey
EvilM0nkey's Avatar
Did the noise change at all after the oil change?
EvilM0nkey is offline
post #3 of 73 Old 03-11-2010, 07:52 PM Thread Starter
97TJnSC
not really maybe is a little louder, the oil hadnt been changed in like 7 months per the old owner.. Im thinkin bout drainin the oil after about 1000 miles or so and putting a lighter weight oil in. I had a mechanic listen to it and he cant seem to offer any info, other then his wifes grand cherokee does the same thing just not as loud.
97TJnSC is offline
post #4 of 73 Old 03-11-2010, 07:52 PM
EvilM0nkey
EvilM0nkey's Avatar
Any chance you can get a recording of it?
post #5 of 73 Old 03-11-2010, 07:54 PM Thread Starter
97TJnSC
i might see if my blackberry will record it.. let me run out there and see..
97TJnSC is offline
post #6 of 73 Old 03-11-2010, 07:56 PM
EvilM0nkey
EvilM0nkey's Avatar
If you're careful and don't run it long you can take the fan belt off and get a recording without the fan noise. Just don't run it too long.
post #7 of 73 Old 03-11-2010, 08:09 PM
0okamiDigital
subscribing. I had an 03 sport that sounded like it had marbles dropped in the engine when i turned it off. like a diesel ambulance. Im curious to see what the OP finds.
0okamiDigital is offline
post #8 of 73 Old 03-11-2010, 08:13 PM Thread Starter
97TJnSC
Ok i recorded two videos.. Again its not a rod knock not sure exactly what it is.. hoping something cheap lol..
YouTube - alltelguy's Channel
hopefully that link will work
97TJnSC is offline
post #9 of 73 Old 03-11-2010, 08:14 PM
97casteeltj
97casteeltj's Avatar
not sure on what the "diesel" noise is....i know sometimes the 4.0s just make some engine noise, but FWIW, i'd change the diff fluids too.
needing a new rig....
97casteeltj is offline
post #10 of 73 Old 03-11-2010, 08:16 PM Thread Starter
97TJnSC
97TJnSC is offline
post #11 of 73 Old 03-11-2010, 08:19 PM
97casteeltj
u sure the PO didn't do a 4BT swap?
post #12 of 73 Old 03-11-2010, 08:19 PM Thread Starter
97TJnSC
yea the diff fluid and timing chain is next to get a change.. ive been doing alot of PM on the jeep.. Also painting the door handles and some other little touches like taking the spare tire holder off and painting bolts, hard top bunch of random things..
97TJnSC is offline
post #13 of 73 Old 03-11-2010, 08:21 PM Thread Starter
97TJnSC
4bt would nice, but not as a daily driver like this thing..
97TJnSC is offline
post #14 of 73 Old 03-11-2010, 09:10 PM
Roye77
2011 JK Wrangler
sounds like an exhaust leak to me from the manifold but kinda hard to tell with out being there.
"All men are created equal, then a few become firemen." ~Author Unknown
"Volunteer firemen do it for free!" ~Author Unknown
Roye77 is offline
post #15 of 73 Old 03-11-2010, 09:21 PM
Skyryder
X2 beat me to it, but I believe there is some lifter/valve noise also.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
Just bought a '87 Wrangler Hoover01 YJ Wrangler Technical Forum 13 05-01-2009 10:22 PM
Just bought a 97 Wrangler Blue97 TJ Wrangler Technical Forum 32 05-18-2008 12:49 AM
Bought my first wrangler Burntrubber87 YJ Wrangler Technical Forum 16 10-03-2007 09:24 PM
So you bought a Wrangler X Metal Cowboy JK Wrangler Technical Forum 18 09-24-2007 06:45 AM
Just bought a New Wrangler! smpross JK Wrangler Technical Forum 8 05-05-2007 01:21 PM
