Just bought a 30/35 combo with 4.10. What am I in for? - JeepForum.com
post #1 of 20 Old 07-22-2010, 10:08 AM Thread Starter
ChrisTJCO
I just found a pair of TJ Dana Axles (30/35) with 4.10 gears for $100. I had to jump on them (I have the 3.07s). I am very excited about these - I can't wait to feel the difference with my 31s!
How difficult of an install is this? I installed my lift kit myself, but I've never messed around with axles. These axles are complete, though the brakes aren't great so I'm going to use the brakes from my current axles. Is there a good write-up for this?
White-Out Jeep
Colorado Jeep Club Member #230
ChrisTJCO is offline
post #2 of 20 Old 07-22-2010, 10:11 AM
theducksguts
Personally I don't see this as a difficult install. Use a lot of PB blaster if you are dealing with rust. An impact gun will help save your body too, other wise a breaker bar will work for you.
The front end will be more complicated in the matter of adjusting the toe in and caster. There is a good alignment thread on here somewhere.
You should enjoy the 4.10's.
Check out my
theducksguts is offline
post #3 of 20 Old 07-22-2010, 10:29 AM Thread Starter
ChrisTJCO
Cool, thanks - I just read a write-up for the rear axle. It sounds like it's as easy as disconnecting the drivetrain, control arms, sway bar links, trackbar, lower shocks, diff. breathing tube, and brake lines and then dropping the axle.
I also screwed up installing my OME springs (swapped passenger/drivers side front AND rear) so this will be a good opportunity to fix that - plus I shouldn't have to use spring compressors if I've dropped the entire axle, right???
White-Out Jeep
post #4 of 20 Old 07-22-2010, 10:36 AM
AFjeepMan
You won't need a spring compressor, attach the upper arms and then put the springs on and jack it up till you can get the lower arms bolted up then reconnect everything else
AFjeepMan is offline
post #5 of 20 Old 07-22-2010, 10:42 AM Thread Starter
ChrisTJCO
Awesome! I'm so excited to have 4.10s instead of my 3.07. I'm assuming I'll see a pretty big increase in power, right?
Wish I could install them this weekend but we're out of town! Rats!
White-Out Jeep
post #6 of 20 Old 07-22-2010, 10:44 AM
Apex
Recon death squad
Apex's Avatar
If this is the first time you have ever swapped an axle...figure a weekend. 1 day per axle (give or take 6ish hours per axle) You could bang em both out in a day if you feel like it.
Having done it before (a few times) I can easily bang out a front and rear swap in a few hours as long as the bolts co-operate.
Apex is offline
post #7 of 20 Old 07-22-2010, 10:45 AM
joshr1987
Itll be a whole new jeep!
joshr1987 is offline
post #8 of 20 Old 07-22-2010, 10:48 AM Thread Starter
ChrisTJCO
Wanna come over? Haha.
I just did the lift about a month ago, so the bolts should be pretty easy. I'll want to bang this out in a day for sure.
White-Out Jeep
post #9 of 20 Old 07-22-2010, 10:48 AM Thread Starter
ChrisTJCO
Woohoo!
White-Out Jeep
post #10 of 20 Old 07-22-2010, 10:59 AM Thread Starter
ChrisTJCO
Any idea how much these axles weigh?
White-Out Jeep
post #11 of 20 Old 07-22-2010, 11:16 AM
jeepster1911
where did you find them?
jeepster1911 is offline
post #12 of 20 Old 07-22-2010, 11:27 AM Thread Starter
ChrisTJCO
On a Colorado 4x4 site. Incredible deal. Every junkyard I called wanted at least 800 bucks for the combo.
White-Out Jeep
post #13 of 20 Old 07-22-2010, 11:51 AM
theducksguts
over 100 pounds each. I didn't weight it but I bet the rear axle is around 150 pounds.
Check out my
post #14 of 20 Old 07-22-2010, 12:26 PM
Apex
Recon death squad
Apex's Avatar
I can pick up a d30 or 35 and walk around with it...I'd assume about 150 is a good guess.
Apex is offline
post #15 of 20 Old 07-22-2010, 12:34 PM
Sundowner
They're not the lightest things in the world, but not unreasonably heavy...I wouldn't want to be under one when it decided to fall on me, though.
To the OP: it's an easy swap...just take your time and study on it. Disconnect anything that connects it to the frame/driveline, and you're done with removal. Since it's the same thing going back in, you'll have an easy time of it. Just turning wrenches, is all. Technically, no more difficult than changing spark plugs...although somewhat more time consuming. Sell those stock axles and make a couple dollars back, and you'll have re-geared for less than $100! Or, even better...keep them for spare parts.
Sundowner is offline
swap , swapping , axle , d30 , d35 , dana 30 , dana 35 , install , installation , 4.10 , brakes , tj , wrangler
4.10 and 4.56 bad combo? geewally9 YJ Wrangler Technical Forum 9 10-28-2009 12:52 AM
YES! I just bought a D44/30 combo for $800 (3.73, 33" tires, 3 spd auto?) chaznad TJ Wrangler Technical Forum 29 03-13-2009 04:52 PM
How bad is this combo? sdlemaster TJ Wrangler Technical Forum 15 06-21-2007 11:05 AM
best buy on sye/cv combo jptaylor2 TJ Wrangler Technical Forum 2 04-04-2006 06:11 PM
anyone run this combo? paroxysym TJ Wrangler Technical Forum 3 03-15-2005 04:09 PM
